Hello,
I am trying to setup a wired LAN between my desktop (which acts as a media file server for my htpc for now until i build a dedicated home media server), and my HTPC for streaming hd video. The router/modem are located on the first floor of the house, and both the media pc, and the desktop pc are on the 2nd floor. so for now, setting up a wired lan connecting directly to the router is out of the question.
Both my htpc and my desktop access the internet via their own wireless adapters. Internet connection speeds are fine for me. average about 30mbit down/8mbit up.. The problem is streaming large HD video from my desktop to my htpc via wireless is just too slow.. and it lags with files over 3gb. I am using a dual band netgear n600 router. What i want to do is connect the machines together via ethernet cable, and use that network just for file sharing. And while still keeping the wireless internet connections. I dont want to have the htpc leach off the bandwidth of my desktop's internet connection, and slow it down.
How can i go about doing this, and getting the machines to differentiate between the two networks? If i disable the wireless on one of the computers, it will transfer through the wired lan at gigabit speeds, but as soon as i do that, it starts stealing bandwidth from the other computer that is still connected wirelessly to the internet. If both wireless adapters are enabled and connected, it only does transfers over wireless. Both machines run windows 7 ultimate right now.
