Solved
Help with wifi?
Last response: in Wireless Networking
May 17, 2012 11:23:11 PM
I want to get a Linksys AE2500 Wireless-N USB Adapter. I need to know if i hook this up to a pc in my room will it recieve wifi from my router in my living room?
More about : wifi
Best solution
a b F Wireless
May 18, 2012 2:34:17 AM
Yes it will work fine!
Earlier this week I installed two Linksys AE1000 wireless adapters on 2 different desktops. Both work fine. Distance 30 feet - 4 walls.
Use the CD and run the CD first. It will prompt you during the installation. After you get it up and running, go to Linksys's site (homesupport.cisco.com) and update the driver to the latest driver.
For reference, read my feedback review on the AE1000 at Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
May 18, 2012 3:29:41 AM
thank you.
I just wanted to make sure before I bought it.
m
l
May 18, 2012 3:29:49 AM
Best answer selected by robertg231.
m
l
