Solved
Can I connect wired to this wireless router?
Last response: in Networking
June 8, 2012 7:25:27 PM
I am going to build my first home network.
I have chosen the Linksys ea3500 looking to eventually stream HD video over the network, and not wanting to buy something I have to replace later.
To start out however, I want to save some money by not buying wireless adapters for two older XP running computers that can sit near the router. Maybe I will buy adapters later, or maybe I'll just retire the computers.
In the meantime, can I just hardwire these two machine into this router using the ethernet ports in the back of the router... essentially not using the wireless feature at all for now.
Thanks,
Best solution
June 8, 2012 9:12:35 PM
Sure, looks like you can wire up to 4 devices to the router
June 9, 2012 11:39:36 PM
Thanks... its good to know for sure
m
l
June 9, 2012 11:39:49 PM
Best answer selected by Crassius.
m
l
