Q: Problem with intermittent disconnect with Linksys router
Hello,
LinkSys wireless G 802.11 router dropping out after running OK for an hour or so. Removed the router and the internet connection was OK. This router has worked OK for several years in this setup.Is the computer getting too slow? The hard drive is nearly 90% full. Running XP on a desktop with a netgear modem.
1 answer Last reply
More about problem intermittent disconnect linksys router
  1. JLSPOOR said:
    Hello,
    What is the model number of your router?
    If it is very old router then you can try to upgrade the firmware on the router.
    After upgrading the firmware, reset the router and reconfigure it.
    :wahoo:
Connectivity Routers Linksys Wireless Networking
