Archived from groups: alt.video.satellite.mpeg-dvb (More info?)
I strapped a DSS LNB to my Linear LNB using plastic ties, and I got it
working quite well. Getting 99-100% quality signal on the Echostar and Nimiq
birds. My question is how is this going to work with my motor (not yet
installed) ? I'm assuming the motor is going to be configued by the prime
LnB (the linear Ku) so If I direct the motor to go to Echostar 7, its going
to use the position of the Linear LNB instead of the DSS one that I want.
how do I take into account that the DSS lnb will be skewed a bit?
There is an option in my Satellite setup called "Skew" and its configured
as -45 or 45. I really don't know what that represents?
Anyone got any tips?
Thanks!
You won't be able to use Usals(diseqc1.3) with the dss lnb, its off center
so the calculations from long/lat/sat pos will be off a bit. You can still
use diseqc1.2 with the motor, just find the satellite, store its position
and you're done.
"Me" <me@me.com> wrote in message
news:FdYoc.77474$FH5.1649309@news20.bellglobal.com...
Nimiq
going
> Thanks!
news:FdYoc.77474$FH5.1649309@news20.bellglobal.com:
> Nimiq birds. My question is how is this going to work with my motor
> (not yet installed) ? I'm assuming the motor is going to be configued
> by the prime LnB (the linear Ku) so If I direct the motor to go to
> Echostar 7, its going to use the position of the Linear LNB instead of
> the DSS one that I want. how do I take into account that the DSS lnb
> will be skewed a bit? There is an option in my Satellite setup called
> "Skew" and its configured as -45 or 45. I really don't know what that
> represents? Anyone got any tips?
> Thanks!
What type of receiver do you have ?
If you have a Fortec Lifetime, I could tell you how I compensate for the
3.5 degree skew using USALS. This is the only FTA receiver that I have
ever used and I don't know about other receivers so I won't go into it
now.
PON
It's a Pansat 2500A.
"Pseud O. Nym" <pon@blurry-vision.com> wrote in message
news:Xns94E95AC9AA916blurryvision@24.93.43.119...
> > Thanks!
> now.
> PON
So you mean I can just use USALS for all the satellites, and then for the
DSS LNB required sats, I adjust them manually and store the results in the
receiver? That way when I do actually tell the motor to move to 119, its
really going to 123 (for example?)
"Brian" <reidb@nbnet.nb.ca> wrote in message
news:J51pc.39904$Np3.1653769@ursa-nb00s0.nbnet.nb.ca...
> and you're done.
> Nimiq
prime
> going
want.
configured
> > Thanks!
"Me" <me@me.com> wrote in news:Uo5pc.78947$FH5.1782081
Sorry but I have to claim complete ignorance when it comes to the Pansat
products. Pansat and Fortec Lifetime may have similar capabilities when
it comes to USALS so I will very briefly describe the procedure that
works great for me. Perhaps you may be able to expand on it so that
something similar works in your situation.
I have a DSS LNBF fastened directly to the east side of a FortecStar
linear LNBF. The EchoStar satellite located at 119-degrees west has a lot
of FREE music channels and a few FREE TV channels ..... including NASA-
TV, AngelOne, and Dish info channels. I will use it as an example.
First I selected the EchoStar-7 entry and let the USALS move my dish to
the correct heading. Then I used the original FortecStar LNBF to look for
a relatively strong channel and made a note of the Freq, vpid and apid
for later use. It can be a scrambled channel. It doesn't matter because
you are just verifying and noting a signal strength reading .... not
watching TV.
Next I created a new satellite entry in my satellite list and called it
"Dish_119". The table will not say 119 when finished so I used this name
as a reminder instead. I went to "Antenna Setup" and selected my newly
added satellite from the listing. Then I entered the previously noted
freq, vpid, apid as the frequency to use and selected USALS and pressed
"OK". At this screen you can enter an estimated heading such as 115.5W
and select "Move" and press "OK". There is a signal strength and quality
graph at the top of the screen. If you think it is not maxed out, just
change the heading to another setting such as 115.8W and repeat the
process until you have determined the position of maximum strength and
quality ..... then select "Save" and press "OK".
Again, the listing does not give the location as 119W but the name of
"Dish_119" tells me instead.
It is true that I could have just modified the original entry for
EchoStar-7 but now I have 2 different entries .... one for each LNBF.
Also if you fastened the DSS LNBF directly to the west side of the linear
LNBF your heading will be approximately 122.5W and if on the East side it
will be approximately 115.5W.
That should give you some ideas.
Good Luck,
PON
Thanks PON, my setup is similar to yours. My LNB is strapped on to the West
side of the Fortec LNB. This gives me enough information to get started, and
good idea on creating a new new satellite entry so I can still use the
Fortec LNB to move to 119. I am mainly interested in NASA and the Radio
channels.
Another question, my DSS LNB won't be plugged into the motor. The Fortec
LNB (single universal) will be plugged into the motor.. is this how yours is
setup?
news:Xns94E97A3B0782Bblurryvision@24.93.43.119...
> watching TV.
> Good Luck,
> PON
news:aEbpc.37671$dr1.1010261@news20.bellglobal.com:
> Fortec LNB (single universal) will be plugged into the motor.. is this
> how yours is setup?
I don't use the DSS LNBF very often. I have the coax equipped with a
slip.on connector where it connects to the LNBF.
When I am in the mood to use the DSS LNBF, I just walk out into the
backyard and unplug the coax from the linear LNBF and plug it onto the
circular LNBF..... or vice versa. It takes me about 2 minutes.
The best way to do it would be to use a 22khz switch or a DISEqC switch.
PON
If you use a DiSEqC switch make sure to put it in line after the motor.
Brian Gohl
Satellite Audio Video
http://www.adventistsat.com
news:Xns94E9DE5D6C051blurryvision@24.93.44.119...
> > how yours is setup?
> PON
this is what I am considering for the configuration:
1. Fortec LNB (Linear) to the motor, from the motor to Port #1 of the DiSEqC
switch
2. DSS LNB (dual cable) to an existing multiswitch in the house (this will
merge DSS and Local Cable signals on a single cable line)
3.A Diplexer will split the cable/DSS single again and will connect to Port
#2 of the DiSEqC switch near the receiver.
The output of the DiSEqC switch will connect to the Input (IR) of the
Satellite Receiver
The DiSEqC switch will be near the receiver, not outside near the Dish
The reason I would like DSS on the existing cable line is so I can still use
my DirecTV subscription on other televisions in the house. I realize that I
would have to position my Dish to a DTV bird before this would work. This
allows me to use a single dish for all FTA and DSS
Is this an acceptable configuration?
"Brian" <b.gohl@comcast.net> wrote in message
news:XbWdnb1dG8QNDDjdRVn-hw@comcast.com...
> Brian Gohl
> > > how yours is setup?
> > PON
do you mean put the DiSEqC between the LNBF and the Motor?
that is, one output of DSS to port 2 of the DiSEqC switch
and the output of the Linear LNB to port 1 of the DiSEqC switch
Then input of the DiSEqC switch to the motor connection.
Motor connection to the Receiver input
Thanks!
> Brian Gohl
> > > how yours is setup?
> > PON
Correct!
Brian Gohl
news:F3Rpc.1624$325.204388@news20.bellglobal.com...
> Thanks!
> > Brian Gohl
this
> > > > how yours is setup?
switch.
> > > PON
Is this because of the motor? because most of the installation instructions
I see the Diseqc switch is installed just before the receiver?
news
budnXikYuY8cDrdRVn-vg@comcast.com...
> Correct!
> Brian Gohl
> > Thanks!
motor.
> > > Brian Gohl
The
> this
> > > > > how yours is setup?
the
> switch.
> > > > PON
Just to clarify, between the LNB and Receiver.
news:%P2qc.9931$qJ5.249322@news20.bellglobal.com...
instructions
> news
> > Correct!
> > Brian Gohl
> > > Thanks!
> motor.
> > > > Brian Gohl
> The
is
> > this
> > > > > > how yours is setup?
a
the
> the
> > switch.
> > > > > PON
When installing a motor, place the DiSEqC switch on the output of the motor
between the motor and the LNB(s).
In a non-motorized setup, DiSEqC switches may be installed at the dish
location or in near the receiver. As cable length can affect the DiSEqC
signal, some opt for placing the switches near the receiver.
Brian Gohl
news:BS2qc.9934$qJ5.250089@news20.bellglobal.com...
> instructions
> > news
> > > Correct!
> > > Brian Gohl
> > > > Thanks!
> > motor.
> > > > > Brian Gohl
> > The
> is
> > > this
> > > > > > > how yours is setup?
with
> a
> the
onto
> > the
> > > switch.
> > > > > > PON
Thanks for the info. Are all DiSEqC switches designed for outdoor
installation? Should I be looking for a "Outdoor" type weatherproof DiSEqC
switch? or are all of them designed for outdoor use?
news:GPqdnbE39-zWVDXdRVn-sw@comcast.com...
motor
> Brian Gohl
> > instructions
> > > news
> > > > Correct!
> > > > Brian Gohl
> > > > > Thanks!
> > > motor.
> > > > > > Brian Gohl
motor.
> > > The
motor..
> > is
> > > > this
> > > > > > > > how yours is setup?
> with
> > a
into
> > the
> onto
> > > the
DISEqC
> > > > switch.
> > > > > > > PON
Not all DiSEqC switches are created equal, but for the most part, most are
well sealed. I'm sure that your fittings will give problems before you have
a waterlogged switch. Covers are nice, but I placed a poly box near my
antennas to keep switches and connections out of the weather.
Brian Gohl
news:Negqc.26582$325.726582@news20.bellglobal.com...
> motor
> > Brian Gohl
> > > instructions
> > > > news
> > > > > Correct!
> > > > > Brian Gohl
> > > > > > Thanks!
the
> > > > motor.
> > > > > > > Brian Gohl
> motor.
> > > > The
> motor..
> > > is
> > > > > this
> > > > > > > > > how yours is setup?
equipped
> > with
> > > a
> into
> > > the
it
> > onto
> > > > the
minutes.
> DISEqC
> > > > > switch.
> > > > > > > > PON
I noticed my switch making a clicking noise today. Is this normal?
I got a Microyal SW22 switch. Does the 22KHz connection go to the Linear
LNB or the Circular LNB? I am confused on this one. One input is labeled
LNB A (22Khz ON) and LNB B?
news:gYqdnY23pZnuNzTdRVn-jA@comcast.com...
have
> Brian Gohl
DiSEqC
> > motor
DiSEqC
> > > Brian Gohl
> > > > instructions
> > > > > news
> > > > > > Correct!
> > > > > > Brian Gohl
switch
> > > > > > > Thanks!
> the
> > > > > motor.
> > > > > > > > Brian Gohl
> > motor.
> > > > > The
> > motor..
> > > > is
> > > > > > this
> > > > > > > > > > how yours is setup?
> equipped
> > > with
> > > > a
> > into
> > > > the
> it
> > > onto
> > > > > the
> minutes.
> > DISEqC
> > > > > > switch.
> > > > > > > > > PON
Doesn't technically matter, but it will be easier to program with the
DBS LNBF connected to the tone on input.
>have
>> Brian Gohl
>DiSEqC
>> > motor
>DiSEqC
>> > > Brian Gohl
>> > > > instructions
>> > > > > news
>> > > > > > Correct!
>> > > > > > Brian Gohl
>switch
>> > > > > > > Thanks!
>> the
>> > > > > motor.
>> > > > > > > > Brian Gohl
>> > motor.
>> > > > > The
>> > motor..
>> > > > is
>> > > > > > this
>> > > > > > > > > > how yours is setup?
>> equipped
>> > > with
>> > > > a
>> > into
>> > > > the
>> it
>> > > onto
>> > > > > the
>> minutes.
>> > DISEqC
>> > > > > > switch.
>> > > > > > > > > PON
Thanks for the info. Are you aware if these switches are supposed to make
the clicking noise? Its seems to be a constant click every few seconds.
"Gary Tait" <classicsat@yahoo.cominvalid> wrote in message
news:n2l1b05ptqkads5hcsivouuv2sdchaaujo@4ax.com...
Linear
are
> >have
> >> Brian Gohl
> >DiSEqC
the
> >> > motor
dish
> >DiSEqC
> >> > > Brian Gohl
> >> > > > instructions
> >> > > > > news
> >> > > > > > Correct!
> >> > > > > > Brian Gohl
switch
> >switch
> >> > > > > > > Thanks!
after
> >> the
> >> > > > > motor.
> >> > > > > > > > Brian Gohl
the
> >> > motor.
> >> > > > > The
the
> >> > motor..
> >> > > > is
> >> > > > > > this
> >> > > > > > > > > > how yours is setup?
> >> equipped
> >> > > with
> >> > > > a
out
> >> > into
> >> > > > the
plug
> >> it
> >> > > onto
> >> > > > > the
> >> minutes.
a
> >> > DISEqC
> >> > > > > > switch.
> >> > > > > > > > > PON
Me, I was reading your posts and was wondering what Frequency your dss
lnb was?
I also was wondering if a person took his LNB from th 18in dish and
attached it to a 9ft dish, would you be able to pick up any of the FTA?
I thought I read somewhere that the dss lnb's were in the 12;2-12.7 ghz
freq. range and i was under the impression that the FTA freq were lower
than that. Any thoughts on this?
Thanks, bob
> Thanks!
There are 1462 identified and unidentified users. To see the list of identified users, Click here.
Nope, nobody has ever done the work to get around the need to pay TiVo for the schedule....
