<i>Crashman says:</i>
Just getting my math mixed up, I knew that Rambus was 8-bit, and that a RIMM had a double wide path at 16-bits
Now you're really confused. It's 16-bit, and effective 32-bit because of the dual-channels.
But now that I think about it, you're kind of right. Assuming that you count the double-pump, it could be actual 8-bits wide, or it could be effective 32-bits wide. Not sure...
<i>Bum_JCRules says:</i>
How about the Hammers?
Now that's where it gets interesting. AMD has taken out a license to use RDRAM, most of us know that. But why? They've already said Hammer will use dual-channel DDR, and they're not exactly a big chipset maker, so they were almost certainly never planning on using RDRAM for the Athlon. So are they hedging their bets, or do they have something in store? I suspect they're just hedging their bets and keeping options open, but who knows.
This could use RDRAM or DDR, DDRII, QDR, QDRII, or whatever they decide to use with it.
Yeup, but the problem is, even though the MCH is on die, you still have to buy a motherboard with slots to fit the memory you want. So the problem of buying a new motherboard for new memory is still there. <i>Unless</i> we move to hybrid motherboards with slots for DDR, DDRII and RDRAM all at once. However, that would be expensive and impractical.
Will the prefetch structures on Hammer
Prefecth will pretty much disappear, to a certain extent. Though it depends on how you look at it, you could say that the MCH disappears and we'll have <i>only</i> data prefetch.
and Itanium
I'm not sure how Itanium fits into this?
<font color=blue>Hi mom!</font color=blue>
