Closed
Toshiba laptop dropping internet connection once unplugging the power cord from
Once I unplug my toshiba saelillite power cord from the laptop itself, I lose my internet connection. Once I plug power cord back into the laptop, I am back online. What do I need to do to fix this?
7 answers Last reply
More about toshiba laptop dropping internet connection unplugging power cord from
  1. Change your power plan wireless setting -- go to Power Options control panel, for whichever is checked select change plan settings, then change advanced power settings, choose wireless adapter settings, and change the power saving mode to maximum performance.
  2. thanks. i'll give it a go. will let yoy know how it turns out. thanks
  3. All my settings were already set up as you stated. I restarted my computer after checking. Got online, connected to my network/ internet, unplugged the power cord and lost internet access immediately. So the problem is still present. Thanks...
  4. If it isn't MS, then it sounds like a manufacturer power saving utility that loads at startup -- check your manual for any power saving programs they install, also you can check your services running to find it.
  5. Thanks. I'll give it a try....
  6. I think Realbeast is on to what your problem is. Go under your power options, for a laptop there should be two sections. One for when your laptop is plugged in, and a second one for when your laptop is unplugged. Change the unplugged section to max performance and see if that helps.
  7. [I'm having the exact same issues and am hoping you have a solution!!! I checked all the settings suggested and everything is at max so I'm very frustrated!! Hopefully you figured something out!!! PLEASE?!?!?
Connectivity Laptops Power Internet Connection Toshiba Wireless Networking
