Tom's Hardware > Forum > CPU & Components > Other Components > Floppy Drive Problem
Forum CPU & Components : Other Components - Floppy Drive Problem
I recently upgraded my box from a Pentuim3-667 based mobo to a Soyo SY K7VTA Pro MB and AMD XP1900+ cpu. I now am getting errors when using the (previously working) floppy drive. I do formating and I get huge numbers of bad sectors from floppys that were previouly good 1.44Mb. I also get errors when copying or pasting to/from the drive. I swapped it out with another drive and cable with the same results. Could the controller be bad on the new MoBo? Should I have done a clean re-install of W98? Any ideas/feedback is appriciated.
Sponsored Links
You should have do a clean installation since you new motherboard use a different chipset.
Reply to upec
- 0 +
Yes a Clean install of Win 98 should straighten it out.
Reply to 4ryan6
- 0 +
May I suggest a clean installation?
This is my new sig.
Reply to Jake75
There are 547 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
