I need some information on buying a TV for someone who is hard of hearing
and wants to listen to the TV with wireless headphones (Sennheiser RS-120).
The TV needs to have the correct type of jack to plug in the headphones base
unit, but in reading specs of TV sets it isn't always clear whether they do
have the right jack, which is an RCA type. I have seen one or two that
specify RCA, but others will just say "Audio output" or "A/V output". I 'm
not clear if this is the same thing and would like some guidance on what to
look for.
On Sat, 07 May 2005 15:46:01 GMT, "Glenn Alcott" <galcott@nyc.rr.com>
>look for.
I imagine the wireless box requires a Line Out. This is typically
provided on a rca jack. But it's the electrical spec. that matters,
not the connector type.
"Laurence Payne" <lp@laurenceNOSPAMpayne.freeserve.co.uk> wrote in message
news:verp715u56a5ut5tcla2au92s4ul28tpu0@4ax.com...
RS-120).
base
do
'm
to
> >look for.
On Sat, 07 May 2005 18:19:18 GMT, "Glenn Alcott" <galcott@nyc.rr.com>
>What do you mean by the electrical spec?
Voltage, impedance. What makes a microphone signal different to a
Line signal different to a speaker output. Though they could all
be delivered from the same socket type.
On Sat, 07 May 2005 21:59:09 +0100, Laurence Payne
Right. If the TV has a headphone (or line) output, the physical jack
does not matter as you can get an adapter to change it to what you
need.
"Glenn Alcott" <galcott@nyc.rr.com> wrote in message
news:Zo5fe.18584$mp6.3669303@twister.nyc.rr.com...
RS-120).
base
do
to
> look for.
> Glenn
If I'm reading it right, the Sennhesier connector is like a standard
headphone connector, so it will plug into a TV headphone output. It will
also connect to an amplifier or CD player headphone output.
The Sennheiser also comes with an RCA-to-headphone-jack adapter, so will
connect to audio devices without headphone sockets.
One thing: the Sennhesier comes with rechargeable AAA batteries. I wonder
how long they can operate between charges. I'd get some spare rechargeable
batteries.
"Tim Martin" <tim2718281@ntlworld.com> wrote in message
news:19cfe.2272$wk4.828@newsfe3-win.ntli.net...
hearing
> RS-120).
> base
> do
'm
> to
> > look for.
> > Glenn
> Here's the SennheiserRS-120 specification sheet
http://www.sennheiser.com/sennheis [...] 120_GB.pdf >
wonder
rechargeable
> batteries.
> Tim
I read the spec sheet and checked out the headphones in a store. They do
connect
to a standard headphone jack or an RCA jack. It seems that virtually no TV
set has an
RCA output and maybe half of them have headphone jacks, at least toward the
lower
end of the TV price spectrum. I'm quite surprised at how many TV sets aren't
equipped
for this kind of connection.
