Hello all,
I'm having difficulties achieving full transfer performance on my home network and I'm looking for some suggestions. Here is my configuration:
Upstairs I have a Win7 Home box (Computer A) connected to a Netgear ProSafe Gigabit 8 Port Switch (Switch A). I also have a Buffalo LinkStation 3T NAS w/ Gigabit connected to this switch. Switch A is connected via a 100' Cat6 cable to another Netgear Gigabit switch downstairs (Switch B). Switch B in turn is connected to a Win XP Pro box (Computer B) and the Fios router. Except for the Fios, everything is gigabit.
All lights on the both switches are trained at 1000MB/S.
I tested transfer speeds between the two computers and the LinkStation. The results are as follows, all times are average of 3 tests:
Test #1 - Single 785 MB file
Computer A to Computer B, Initiated from A (Win7): 21 MB/S
Computer A to Computer B, Initiated from B (Win XP): 19 MB/S
Computer B to Computer A, Initiated from A (Win 7): 47 MB/S (since this was such an outlier, I did it 5 times, all about the same)
Computer B to Computer A, Initiated from B (Win XP): 20 MB/S
Computer A to LinkStation, Initiated from A (Win 7): 22 MB/S
Computer B to LinkStation, Initiated from B (Win XP): 11 MB/S
Test #2 - 20 MB folder with 195 files
Computer A to Computer B, Initiated from A (Win7): 4 MB/S
Computer A to Computer B, Initiated from B (Win XP): 2 MB/S
Computer B to Computer A, Initiated from A (Win 7): 4 MB/S
Computer B to Computer A, Initiated from B (Win XP): 4 MB/S
Computer A to LinkStation, Initiated from A (Win 7): 2 MB/S
Computer B to LinkStation, Initiated from B (Win XP): 1 MB/S
Questions:
The obvious first question is why is it so much slower to transfer many small files than one large one? Yes, I know there is handshaking going on for each file. But 20 MB/S down to 2 MB/S ??!! That's a little extreme don't you think?
Next, why am I able to achieve nearly 50 MB/S in one configuration, but can't get higher than about 20 for all others?
What is a realistic expectation for consistent transfer speeds on a home network? 50 MB/S? 60? 100?
And bottom line, how do I achieve said high throughput; although truth be told, I'd be happy to get 50 consistently.
Thanks!
Questions:
Thanks!
