Tom's Hardware > Forum > Audio > Audio Technology > Harmon Kardon 720 Power Output Transistors
Forum Audio : Audio Technology - Harmon Kardon 720 Power Output Transistors
Archived from groups: rec.audio.tech (More info?)
As a summer project with my son, we are restoring a
Harmon Kardon model 720 stereo receiver which he found in a
neighbor's trash.
This is a mid-sixties transistor unit, with a quirky
topology: the output pair is two PNPs transformer fed
from the driver transistor, and the speaker is
direct coupled without a capacitor.
Though the schematic is clear that the outputs are
PNPs (both from the direction of the arrows in the
transistor symbols and the polarity of the power supplies,
negative being connected to the collectors and positive
to the emitters) what's actually installed in our
unit is 2N3055's which are NPNs.
These transistors must be completely fried, if not vaporized.
The funny thing is, some sound does come out, not just noise
but recognizable music & speech. Also, the date codes on
two of the 2N3055's is 1968 and on one is 1972. The 4th
transistor is a plastic package with the leads bent to fit
in a T03 socket. I mention the dates and varieties of devices
because one might guess that the unit was repaired multiple
times and it actually worked for several years in between.
Hard to believe, I admit.
Any idea why someone did this apparently crazy substitution,
and what are the original HK PNPs? The service manual just
gives an HK number (H43020418).
Thanks for your help.
Geno Rice
Sponsored Links
> neighbor's trash.
Easy enough with that topology to rewire the output section
to use NPNs. Why not ask the neighbour about its history?
Eiron.
Reply to Anonymous
There are 1095 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
