Tom's Hardware > Forum > CPU & Components > Sound Cards > Help: Sound Blaster Audigy X-Gamer
Forum CPU & Components : Sound Cards - Help: Sound Blaster Audigy X-Gamer
Hello:
I recently purchased a Sound Blaster Audigy X-Gamer. After prolonged use of any software that uses the soundcard, my computer will freeze while the speakers make a continous beep sound. Is this a driver issue or is this a hardware issue? Anyone run into this problem?
I'm currently using an Intel PIII667 with a VC820 Motherboard, Nvidia GeforceMX400 with 256MB RDRAM. Any help is appreciated.
Many thanks,
Claude Luu
Sponsored Links
Try completely uninstalling the soundcard software, then relocate the soundcard as far from the video card as possible and reinstall it.
Reply to 4ryan6
Attempt to get your SC and GFX card on seperate IRQ's as well.
The itsy bitsy spider climbed up the empires state building, along came goblin, wiped the spider out
Reply to williamc
PCI slot 3 is supposed to be the magical sound card slot :wink:
<font color=blue>Hi mom!</font color=blue>
Reply to FatBurger
Ah, slot 3 generally works because of the way the bios assigns IRQ's. The general idea is if your gfx is in agp, sound in slot 3, nic or modem in slot 5 or 6 then theoretically you dont have to modify the bios to get em all on different irqs. Bus mastering is a pain in the arse, all irq's should be set manually by default instead of automatically, more plug and pray making our lives harder than neccessary. Then i'd get more work too, setting everyone's irqs-)
Reply to williamc
There are 992 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
