Hello everybody I hope that someone can help me
Ive got a car linksyswmp600n , but the sigal is worse as it was with tplink 7200nd.
The difference you can see here :
http://img140.imageshack.us/img140/619/beznzvu2r.jpg
I tryied to check both of antena conectors.When I tryied the right one , i havent got any signal.
When the other one Ive got 2-3 ssids.Wen both it was the same.
My question is if the card is faulty or it is normal because the seller says that it has a mimo technology ad i cant check the conenctors without each other
But i think its a bullsh** because when its multiple in/outpu , every antenna should have some gain or ?
