Tom's Hardware > Forum > Home Cinema Equipment > MPEG DVB > multi LNB dish help
multi LNB dish help
Forum Home Cinema Equipment : MPEG DVB - multi LNB dish help
Archived from groups: alt.video.satellite.mpeg-dvb (More info?)
Can I use the following on my fortec
a Triple LNB Direct TV satellite dish which receives the HDTV channels. - 3
LNB's - best on the market! You will get broadcasts from all three DIRECTV
satellites (at 101, 110, and 119 degrees), including HD content, local
channels for some areas and the ability to connect four receivers. These
dishes are designed to stand up to the severest weather and atmospheric
conditions, and can withstand 50-75 mph winds. Some of the Key Features are:
Multi-satellite dish antenna with a third LNB, built in integrated
multiswitch lets you connect up to four DIRECTV receivers, Sat-C LNB
receives content from the 110-degree satellite, which broadcasts some HDTV
programming with HDTV-compatible DIRECTVPlus receiver required to receive
HDTV programming and the actual dish size is 21-1/8"W x 18-1/2"H.
Sponsored Links
"Tractorman" <tractorman@charter.net> wrote in message
news:10gj8f23stql2bf@corp.supernews.com...
DIRECTV
are:
the fortec wont pickup anything on the directv satellite, however, you can
get the few free channels from the dishnetwork satellites at teh same
locations, you wont get any HDTV or the others channels
Reply to m0nkey
but can i aim this dish at other sats and pick up what they have
"m0nkey" <allah@achtung.com> wrote in message
news:2mtofpFr512fU1@uni-berlin.de...
channels. -
> 3
> DIRECTV
> are:
HDTV
receive
Reply to Anonymous
This dish would probably not be very useful, unless you can find two DBS
satellites that are 18 degrees apart that have DVB programming you want to
see.
You may be better off with a 30" dish that can pick up Ku FSS satellite
signals, perhaps along with a positioner motor to enable you to try out
any satellite in the arc that you can see.
Note that FSS and DBS satellites require different LNBs. You can tack a
DBS LNB onto an FSS dish and get DBS signals, but not really vice-versa
(most DBS dishes are too small).
Reply to Anonymous
On Thu, 29 Jul 2004 21:18:22 -0400, "Tractorman"
Sure you can, nothing on 101 for you to see so you can leave that LNBF
off. You also don't want the DirecTV sat-c LNBF.
Reply to Anonymous
So what everyone is saying is this item is a waste of money unless I am
intrested in hacking D***
DIRECTV
are:
Reply to Anonymous
On Fri, 30 Jul 2004 08:41:40 -0400, "Tractorman"
Or legitmately subscribing to the service.
>3
>DIRECTV
>are:
Reply to Anonymous
Not D***, but D******.
Reply to Anonymous
The dish you are referring to will get you free music. A 1.2 with a
diseq motor will serve you much better.
>3
>DIRECTV
>are:
Reply to Anonymous
what is a 1.2
and who does everyone suggest i buy from
"kryppy" <kryppy@.> wrote in message
news:dvfog0tsg1712721umhi2pv7bmo9tvl0uk@4ax.com...
channels. -
> >3
> >DIRECTV
These
> >are:
HDTV
receive
Reply to Anonymous
- 0 +
news:10grhuhcqf4q9ea@corp.supernews.com...
> what is a 1.2
in this case i think1.2 refers to a reciever that has diseq 1.2 function,
you move the dish and the motor via the reciver, you find the satellite,
then save it, you move onto the next satellite, then save it, you then can
have the reciever move the dish automaticly when you switch to a channel on
a differnt satellite.
alot of recievers have diseq 1.2 and 1.3, i got my reciever and motor from
http://www.sadoun.com about 18 months, and have had no problems with them.
very good site and forums.
Reply to m0nkey
I think he meant a 1.2 meter dish. Perhaps.
Tractorman wrote:
> what is a 1.2
> channels. -
>>>3
>>>DIRECTV
> These
>>>are:
> HDTV
> receive
Reply to Anonymous
On Sun, 1 Aug 2004 21:26:03 -0400, "Tractorman"
>what is a 1.2
1.2 meter dish. (4 feet)
>channels. -
>> >3
>> >DIRECTV
>These
>> >are:
>HDTV
>receive
Reply to Anonymous
There are 1038 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
