Tom's Hardware > Forum > Home Cinema Equipment > MPEG DVB > Help setting up blackbird with big dish
Forum Home Cinema Equipment : MPEG DVB - Help setting up blackbird with big dish
Archived from groups: alt.video.satellite.mpeg-dvb (More info?)
I bought a used blackbird to add to my c-band dish.
Got the Hi-Freq switches and DiSEqC 2.1 switch all
hooked up, c-band works great but I'm having trouble
setting up the FTA. Any pointers.
1. LNB type should it be? >> normal or universal
2. LNB should it be? >> power on or off
3. should I use option? >> 22KHz Tone or DiSEqC
4. If I use DiSEqC? >> should I use Port A,B,C or D
thanks much
Sponsored Links
Normal
off
diseq
Choose the port you have C and KU on, probably A & B ...?
>thanks much
Reply to Anonymous
There are 611 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
