Tom's Hardware > Forum > Storage > Hard Disks > Scandisk problems
I was defragging my brother's computer the other day when it got stuck on 70%. I ran scandisk again and disabled his virus scanners but it still would just work for about 2 minutes then say "drive contents changed". How do I get it to defragment the whole drive?
Censorship makes us so much more creative.
Sponsored Links
You need to make sure nothing else is running. Either kill processes in the task manager, or boot in safe mode.
<i>Does this count as Community Service, Officer?</i>
Reply to poorboy
Do a "Ctrl-Alt-Del" to get to Task manager then End Task on everything EXCEPT <b>Explorer</b> & <b>Sys Tray</b>. Now you shouldn't have any problem running scan disk or defrag
<font color=purple><b>An average human brain weights aprox. 3lbs., but a thought weights a load.</font color=purple></b>
Reply to jc14all
now what is the next rook?
Reply to mfud
but sometimes "Ctrl-Alt-Del" is screwed. what can we do in that case?
Reply to mfud
you cant. the only remedy is to reformat your hard disk.
Reply to mfud
It is obvious that a task is running in the background interferring with the scan disk/defrag operation. This is a simply problem, I don't know what you mean by:
Quote :
If "Ctrl-Alt-Del" doesn't correct this problem a format surely will...huh? Please explain what you are trying to say?
Formatting for the sake of formatting is what I call black-box troubleshooting. If it doesn't turn-on don't bother trying to figure it out, just buy a new one.
Reply to jc14all
It took me awhile, but I found it:
<A HREF="http://content.techweb.com/winmag/fixes/scandisk.htm" target="_new">Speed Up ScanDisk</A>
by Dave Methvin, former WinMag.com writer
Bryan
<A HREF="http://www.btvillarin.com" target="_new">btvillarin.com</A>
<font color=red>Site's back up! L33t!</font color=red>
Reply to btvillarin
You do amaze me.
Nice going.
<font color=green><b>Inside every older person is a younger person wondering what the hell happened! :eek:
Reply to OldBear
Thanks!
Reply to btvillarin
I also commend you my friend. When you have a headache you don't call a surgeon, but you my friend brought what the PC doctor orders. WTG! Also, a nice bookmark. Thanks.
Reply to jc14all
There is a very nice benchmark software, Ziff Davis Media Win Bench (WWW.ZDNET.COM) . This benchmark suite includes a utility called startup manager. This utility allows you to select what application has to start at the boot. You may avoid that all undesired software are initialized at the start up changing the HDD content during the defragmentation.
Reply to unoc
It's sure is nice to be appreciated. :smile: I think I'm gonna cry...
Reply to btvillarin
There are 1132 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
