The short of it;
Installed new hard drive. Preceded to load all software needed for hardware.
Upon reboot win98SE asks "new hardware found= 'unknown device'. I have no idea what it is trying to detect.
One more 'new hardware found' = PCI System management bus ????
I point it to the win98SE CD (in all directories) and to my Abit Hot Rod 100 controller and still cannot figure it out.
I suspect that is one reason my gameport isn't working because I get a warning in the game controller via control panel that 'gameport drivers are not configured'.
That led me toward reinstalling the soundcard software. After a clean reinstall I get another warning 'Vortex adapter not in primary bus. MPU 401, and joystick may not work on secondary bus'.
So if I can figure out what hardware the OS is finding at startup and then find the files it needs then my gameport my start working (Aureal properly detecting itself on the primary bus-it is in 1st PCI slot now).
Thanks people, don't want to ditch my gamepad for a newer USB one just yet.
DREW
DREW
