Yes No
Ads
Tom's Hardware > Forum > Brands > Ericsson > SonyEricsson t610 power question
Forum Brands : Ericsson SonyEricsson t610 power question
Archived from groups: alt.cellular.ericsson (More info?)
The SonyEricsson t610 says that it has a standby time of up to 13 days.
Without using my phone my standby time on a full charge is about 3 or 4
days. This phone is brand new.
Where the phone is most of the time the reception is very low, would this be
the reason for the very poor standby time or is this new SonyEricsson t610
defective?
Reply to peter
[POSTED TO alt.cellular.ericsson - REPLY ON USENET PLEASE]
In <p_9td.47545$VL6.44463@clgrps13> on Tue, 07 Dec 2004 04:05:41 GMT, "peter"
>the reason for the very poor standby time ...
It probably is the reason.
Best regards, HELP FOR CINGULAR GSM & SONY ERICSSON PHONES:
John Navas <http://navasgrp.home.att.net/#Cingular>
Reply to Anonymous
Try also to disable Bluetooth, some older Firmwares were drawing a lot
of power when Bluetooth was enabled.
HTH
Gottfried
Reply to Anonymous
John Navas wrote on 07 dec 2004 in alt.cellular.ericsson:
>>this be the reason for the very poor standby time ...
Because output power on maximum with a poor connection.
Evertjan.
The Netherlands.
(Replace all crosses with dots in my emailaddress)
Reply to Anonymous
>defective?
Two things.
1). It takes several charge cycles for the battery to achieve full
capacity
2). The biggest impact on standby time is often the frequency of the
network poll, and some operators poll at lot more often than others.
Reply to Anonymous
- 0 +
Thanks all for your helpful answers. I am going to exchange this t610 with
another one since I can without any penalty since it is new. My t310 lasts
way longer in standby compared to the t610 which is lucky if it can last 3
days (that with everything off i.e. Bluetooth, magicword, ir and no phone
usage.)
By getting a new one I will be able to tell if this phone is faulty or if it
is normal. Seems strange though that it says that it can last up to 13 days
and then only lasts 3. Should have the new phone with in a week. Will post
the new results. Once again thank you for all your helpful replies.
"matt weber" <mattheww50@cox.net> wrote in message
news:n6ncr09mflhqaff82t61jcc4slahl8mh1j@4ax.com...
>>be
>>defective?
> Two things.
> capacity
Reply to peter
- 0 +
I have had my new replacement T610 cell phone for a few days now and it is
way better on power. There must have been something wrong with either the
previous phone or battery.
"peter" <nospam@nospam.net> wrote in message
news:CFUtd.6557$U47.1755@clgrps12...
> with another one since I can without any penalty since it is new. My t310
> lasts way longer in standby compared to the t610 which is lucky if it can
> last 3 days (that with everything off i.e. Bluetooth, magicword, ir and no
> phone usage.)
> it is normal. Seems strange though that it says that it can last up to 13
> days and then only lasts 3. Should have the new phone with in a week.
> Will post the new results. Once again thank you for all your helpful
> replies.
>>>be
>>>t610
>>>defective?
>> Two things.
>> capacity
Reply to peter
There are 1502 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Surfboard 5120USB "At least 32 MB of RAM"
By hang-the-9, 39 days ago:
Unless you have it setup with a USB connection, you don't need the software.
Best offers
