Tom's Hardware > Forum > Home Cinema Equipment > MPEG DVB > Does altitude help?
Does altitude help?
Forum Home Cinema Equipment : MPEG DVB - Does altitude help?
Archived from groups: alt.video.satellite.mpeg-dvb (More info?)
Hi,
I wondered about receiving KU FTA off Hispasat 1C from SE Arizona, US.
The "look angle" calculator says I'm -.4 below. Could my 5000 ft
elevation-location help? Is it usually possible to get signal from
these fringe locations--like 1 or 2 degrees elevation above horizon?
What's someone's technical evaluation in terms of dish size, lnb, etc.
Thanks,
Largo
Sponsored Links
On Fri, 24 Sep 2004 17:32:35 -0700, Largo <tryagain@fullBS.bad.lnk>
wrote:
>Hi,
Seems to me the 5000 ft would help. I would whip out a 1.8 meter and
try it.
I get it here in South Florida if that helps., :)
Reply to Anonymous
Largo wrote:
> Hi,
> Thanks,
> Largo
You also need to be within the beam's footprint. Are you?
Reply to Anonymous
- 0 +
On Sat, 25 Sep 2004 06:19:17 GMT, Zoyburg <rats@attib.com> wrote:
>Largo wrote:
>> Hi,
>> Thanks,
>> Largo
Yes, it appears I'd be inside a 45 DBW ring. What size dish would
this need?
Thank you.
Largo
Reply to Largo
"Largo" <tryagain@fullBS.bad.lnk> wrote in message
news:aqe9l0dppqbvgrt2p0nva08q07jp1u1o38@4ax.com...
> Hi,
> Thanks,
> Largo
It would seem to me if you are below the horizon then you are below the
horizon and are beyond a "fringe" situation even at 5000 ft elevation.
However experiement! Get the largest dish you can and a standard or
universal lnb and go for it.
Reply to Anonymous
no matter if you are at sea level or on top of a mountain your latitude and
longitude still remains constant. Even if you were able to "look" at those
satellites over the horizon, the footprint beam would probably be diminished
and none existant by the distance alone and the signal would probably be very
weak.
Reply to Anonymous
- 0 +
>weak.
I wanted to know the possibility of getting FTA off Hispasat. Lyngsat
for 30W "Hispasat" appears that I'd be able to "see it" although
Hispasat 1C footprint say's I won't.
My next question is about lyngsat. What's the difference between the
European and the American beam? I assume that if programming says
this or whatnot is on the European beam, I won't be able to receive
it--even if the satellite is easily visible from my ground station
because that signal (and programming) is spotted onto another
continent. Is this assumption correct?
Thanks for your assistance.
Largo
Reply to Largo
Yes; you have to look at the footprint map of the appropriate beam.
Reply to Anonymous
There are 1227 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
