I have an ECS K7S5A motherboard, 1 GHz Duron, 64Mb RAM to begin, now 160 Mb, Win2K pro, ATI Radeon 7500 All in Wonder. Loaded drivers and software from CDs that came with 7500 AIW, had BSODs and some other problems. Added RAM and installed latest AGP driver for motherboard, latest drivers and software from ATI. Everything working pretty good, except no audio on one TV channel. Sent problem report to ATI and called tech support. They said uninstall all ATI drivers and software, and reinstall new drivers and software from scratch. Did so, but after installing video card drivers, the display will not sync properly horizontally. Going to safe mode, VGA enabled safe mode, the display could be read, but not normal boot. Formatted hard disk and did clean install of win2K, direct x 8.1 and applications. Tried installing new ATI drivers and software, and had same problem, if tried to raise resolution from 640x480 to 800x600. Started with another clean install and added ATI drivers and software from CDs to start, and had same problem with no horiz sync - yet this should be the same as original installation!!!!!!, which worked fine except for the audio problem on one channel. Someone please help.
