Tom's Hardware > Forum > Mobility Brands > Ericsson > T610 and data cable - help!
Forum Mobility Brands : Ericsson - T610 and data cable - help!
Archived from groups: alt.cellular.ericsson (More info?)
Hi all
Just back on this ng, was here a while ago.
Right, bought a DCU-11 USB data cable for my T610
plugged the usb cable in, pc detected it and drivers installed etc....
so far so good.
but, I cant seem to get the computer to spot that there is a phone attached
to the end of the cable.
have installed software that came with the cable but nada, nowt, zilch :-((
Two possibilities:
*The cable is faulty [its brand new]
*I'm doing something wrong [probable]
Can any kind soul help out? Have googled but not really found anything
useful :-((
Would appreciate any help.
Regards & seasons greetings
No66y©
Those who find they're touched by madness
Sit down next to me
Reply to address is a spam trap.
Use no66y [at] breathe [dot] com
Sponsored Links
Have you installed the software from Sony Ericsson that allows syncing
the phone? If not, it's available on their website at support, or you
can get some answers at this website;
http://www.clubsonyericsson.com/en [...] dows.shtml
JPH
no66y© wrote:
> Hi all
> so far so good.
> Two possibilities:
> useful :-((
Reply to Anonymous
"J Haggerty" wrote in message
> the phone?
Yep, tried every bit of software I could.
The mobile phone monitor doesnt even detect the phone :-(
Maybe the cable is duff?
No66y©
Sit down next to me
Reply to Anonymous
"no66y©" <bounce@bounce.com> ha scritto nel messaggio
news:1103976133.38518.0@dyke.uk.clara.net...
if it is a serial cable, launch hyperterminal or equivalent comm sw,
connecting directly to the serial port the cable is plugged into. Then you
should see the phone as a plain old intelligent modem (type AT and it
should answer OK).
If it does, the cable and the phone interface are fine.
ciao
VA
Reply to Anonymous
"Vincenzoni Attilio" wrote in message
Hadn't thought of that route.
The cable is a USB one, so I ran the "add modem" wizard and it detected the
phone
on the end of the cable! Now I'm confused...........
I'd become convinced that the cable was duff, hence the reason the phone
monitor wouldn't detect it.
But, that little test proves the cable is fine?
Now I'm stumped....
No66y©
Sit down next to me
Reply to Anonymous
news:1104057538.30308.0@spandrell.news.uk.clara.net...
> the
> phone on the end of the cable! Now I'm confused...........
yes it proves that it communicates to the phone over the cable.
You can use the phone as a wireless modem on the go.
As for "seeing into the phone" the way you explore a windows disk, you will
need another program that interrogates the phone over the cable (or over BT
or the IR) and builds a visual tree of what is inside, eg. FMA from
sourceforge.net.
I am not avare of phones which can be plugged directly into the PC via usb,
and get recognized as external memory, the way a flashpen does.
Reply to Anonymous
will
BT
> sourceforge.net.
Thanks for the help, I'm just downloading FMA now.
Basically all I want to do is send files [ringtones, games, pictures] to the
phone
and send pictures from the phone to the pc.
Will see how FMA goes :-)
cheers
No66y©
Sit down next to me
Reply to Anonymous
"no66y©" wrote in message
and it doesnt connect to the phone :-((
No66y©
Sit down next to me
Reply to Anonymous
news:1104063163.56119.0@doris.uk.clara.net...
The cable driver or software will allow you to map the USB phone cable to
one COM port, wont'it?
If so, FMA, tools, options, general, check the serial interface and select
the COM port the USB cable is mapped to.
Reply to Anonymous
Thanks for the continued advice.
I'm not sure what I actually did but its working now :-)
I reinstalled a different [newer? older? cant remember now] version of phone
monitor, ran fma again and bingo!
Thanks once again for all the help.
cheers!
No66y©
Sit down next to me
Reply to Anonymous
There are 1262 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
