I need some advice or suggestions/opinions about deemphasis switching
when using an external DAC with a CD player.
I recently purchased a used Musical Fidelity Tri-Vista 21 DAC. This is
my first experience using an outboard digital processor.
I am using an older (unmodified) Magnavox/Philips CDB-560 CD player as
a transport, connecting the coax digital output of the player directly
to the coax digital input of the DAC.
The combination seems to work very well, and the sound is an
improvement over the CD player's built in DAC and output stage.
I was fooling around yesterday, checking channel balance, frequency
response, square wave shape, etc. using my CBS CD-1 Test CD and
oscilloscope, and all looked good until I checked the deemphasis
frequency response.
The DAC is obviously not applying any deemphasis when required.
The Magnavox player itself applies deemphasis correctly, with the
proper response seen at its own analog outputs.
I can think of three reasons why the (expensive) Tri-Vista 21 DAC would
not properly deemphasize the test signal:
1) The processor is broken or not working properly... doubtful, because
the unit is otherwise working properly, and is not very old, and is in
excellent condition.
2) The processor is not designed to apply deemphasis, and does not
contain the required circuitry... Possible, but all of the other
Musical Fidelity DACs and CD/SACD players that I have been able to find
info on all contain deemphasis circuitry (and some of the cheaper ones
even have LED indicators on the front panel display).
3) The digital output signal from the Magnavox somehow does not
properly "activate" the deemphasis circuitry in the DAC.
I don't really understand the proper design of digital interfaces, but
I understand that the standard S/PDIF digital output signal is supposed
to contain a "flag" or "bit switch" that tells the processor whether to
apply deemphasis.
In the Magnavox player the deemphasis is applied as additional elements
in the feedback loop of an op-amp in the first filter stage (at the
player output), and is simply switched by an FET, directly controled by
a "DEEM" signal from the decoder chip.
The Magnavox player uses the Philips SAA7210 decoder, SAA7220 digital
filter, and the TDA1541 DAC chips.
Is it possible that the digital output from the Magnavox player does
not contain the proper "bit" to switch deemphasis in an external DAC?
If so, is there a way to "activate" the switch?
Or does anyone know if the Musical Fidelity Tri-Vista 21 actually
contains deemphasis circuitry?
I reallize that most CDs are not preemphasized, and I have no way to
check individual discs anyway, but I am definitely curious about this,
and interested in any wisdom or advice anyone can give!!
<spampup@aol.com> wrote in message
news:1121455489.120692.140610@g14g2000cwa.googlegroups.com
> Hi, all,
deemphasis
> switching when using an external DAC with a CD player.
DAC.
> This is my first experience using an outboard digital
> processor.
CD
> player as a transport, connecting the coax digital output
of
> the player directly to the coax digital input of the DAC.
an
stage.
> frequency response, square wave shape, etc. using my CBS
CD-1
> Test CD and oscilloscope, and all looked good until I
checked
> the deemphasis frequency response.
required.
Not the least bit unusual.
with
> the proper response seen at its own analog outputs.
21
> DAC would not properly deemphasize the test signal:
> doubtful, because the unit is otherwise working properly,
and
is not very old, and is in excellent condition.
does
> not contain the required circuitry... Possible, but all of
the
> other Musical Fidelity DACs and CD/SACD players that I
have
> been able to find info on all contain deemphasis circuitry
> (and some of the cheaper ones even have LED indicators on
the
Most likely answer.
does not
> interfaces, but I understand that the standard S/PDIF
digital
> output signal is supposed to contain a "flag" or "bit
switch"
> that tells the processor whether to apply deemphasis.
additional
> elements in the feedback loop of an op-amp in the first
filter
> stage (at the player output), and is simply switched by an
> FET, directly controled by a "DEEM" signal from the
decoder
> chip.
SAA7220
> digital filter, and the TDA1541 DAC chips.
> player does not contain the proper "bit" to switch
deemphasis
> in an external DAC?
Possible but unlikely.
Not if the DAC follows modern conventions and does not honor
it.
> actually contains deemphasis circuitry?
Vendor still in business?
no
> way to check individual discs anyway, but I am definitely
> curious about this, and interested in any wisdom or advice
> anyone can give!! '
Conventional wisdom is that the demphasis bit is hardly used
and nobody who could do anything about it is losing much
sleep over it.
Sorry, but that is how things seem to be these days.
I would say that the MF, just like nearly all recent players or DAC's, don't
care about de-emphasis, which has been used on a very small number of CD's
years ago and is considered as obsolete by all manufacturers, even if still
part of the Red Book.
The deemphasis may be implented in the analogue part and consists of
two resistors, a capacitor and some switching element per channel.
The switch can be a transistor or a relay.
More recent DAC designs have the deemphasis implemented in software.
A circuit diagram of the DAC should tell it.
You can always burn a audio CD on your computer and set the emphasis
flag for the track - even without processing the music. If the DAC is
working correctly you should easily detect a dull playback for a track
with the emphasis bit on.
"Norbert Hahn" <NorbertHahn@gmx.net> wrote in message
news:bh6gd1llvbhvo64hmlug05q39p8m0dksp1@4ax.com
> software. A circuit diagram of the DAC should tell it.
Good point to bring out. A number of DAC chips have the
feature built in. But as a rule, the people who make the
equipment that those chips go into don't implement the
feature.
> frequency response.
Have you ever heard of CDs actually using the pre/de-emphasis feature ?
I think there is a very good reason why they chose not to bother
implementing it !
>implementing it !
I do have one or two which use this feature. The only one which comes
to mind is a sampler CD, which probably dates back to 1990 or so. I
don't think I've seen preemphasis used in any CDs made in the last few
years.
The sampler CD led to a somewhat confusing behavior... the CD player I
owned at the time would make a distinct "click" when changing from one
track to the next. Turned out that some tracks used preemphasis, some
did not, and the deemphasis logic was implemented via a discrete
low-pass analog filter (after the DAC per se) which was switched into
the circuit via a small relay on the CD player PCB.
Dave Platt <dplatt@radagast.org> AE6EO
Hosting the Jade Warrior home page: http://www.radagast.org/jade-warrior I do _not_ wish to receive unsolicited commercial email, and I will
boycott any company which has the gall to send me such ads!
