The thing is, no program can detect my soundcard in dos, and this causes hangups and other stuff.
Does anyone know where i can find drivers for dos, or fix this problem?
SET BLASTER=A220 I5 D1
A, adress
I, Interupt
D, DMA
Hopes this helps somewhat, or hang around and someone might give you some more advice.
If you are in a hurry you can always try to enter other values other than that I wrote.
This is my new <font color=blue>Updated</font color=blue>, <font color=green>Eatable</font color=green> & <font color=red> Fresh </font color=red> sig.
Which Soundblaster model do you have? With any old ISA SB, you don't need any drivers. With the Live! and Audigy, for sound in a Windows DOS box you need to have SB16 emulation enabled and for real mode DOS you need to run a program called SBEINIT. Both of these drivers can be found on the Live! CD, not sure about Audigy.
Jake, my autoexec.bat says its just a file created by some setup program, and the real file is saved under the name autoexec.tsh, so i edited that.
i added the line SET BLASTER=A400 I9 D1
under "system" from controlpanel, and Sound Blaster Audio PCI properties, it only gave me the IRQ and something that said E400.
okay i surfed a bit on creatives support page, and i seem to be missing the whole /dosdrv directory. i cant download it from their page, so can anyone zip the directory and mail to me with the files, and i would be grateful. its worth a try.
That Autoexec.tsh is just a backup file of the original autoexec.bat file.
When you boot your computer and enters DOS, it will read autoexec.bat and config.sys and execute whatever commands they contain.
Editing the .tsh file will not help you...cut & paste that line and throw it into the .bat instead.
Sure, I can mail the files to you...just PM me your mailadress and I send it.
Here´s an <A HREF="http://www.modarchive.com/help/sblive.shtml" target="_new">link</A> that might come in handy.
By the way, the autoexec.bat files says "This file was created by the System Configuration Utility as a placeholder for your autoexec.bat file. Your actual autoexec.bat file has been saved under the name autoexec.tsh"
And under that, it clearly says "DO NOT EDIT THIS FILE"
I tried to add the line to that file before, but then it couldnt load explorer.
And also, the autoexec.bat file does not contain any command lines at all. Its all in the tsh file instead<P ID="edit"><FONT SIZE=-1><EM>Edited by argan on 06/13/02 09:09 PM.</EM></FONT></P>
Odd.
In my experience (I may be wrong), windows only checks the
Autoexec.bat file when it starts. (ofcourse, there´s alot of other files as well, but no more .bat files?)
Anyways, I sent the drivers so report back if you solve it or not! (sorry about the delay, bedtime you know )
The file I sent you, I copied right of my installation CD so they should work, however I found new files on some german site...I send them to you and hopefully they work.
Ain´t DOS wonderful!
well, arent they all just packed together before installing them? i mean, do you have the drivers installed? then there should be some other files, since these are only some setup and data files i think, unfortunately
seems it didnt work with those files...i suspect there are system files in the folder as well and not just those execution files. ill see if i can find something too.
Good hunting, I´ll keep my eyes open for other solutions.
