I'm currently in the process of ripping my entire CD collection onto my
PC with the hope of eventualy being able to play my playlists that I
build on my PC on my home audio speakers. I purchased a nice sound
card from soundblaster that has a SPDIF digital out. I would like to
run a cable directly to my McIntosh control unit but I dont have a
SPDIF IN. I know products exist out there that will convert my SPDIF
OUT to RCA but I want to minimize noise. Any reccomendations?
All audio DACs, A/V receivers and preamp/processors take S/PDIF
directly via their digital coaxial inputs. Which McIntosh unit do you
have?
Kal
On 19 Jul 2005 13:05:52 -0700, "Clay" <clay_miner@hotmail.com> wrote:
>Hi all,
>Thanks,
>Clay
The truth is I'm setting this up for my father who is an audio nut, and
im the computer dork. Assuming his unit will work, which cable should
I buy, and from where? Also, the length of the cable must be 40+ ft.
Is this going to be a problem?
First, you have to be certain he has an available digital input and
confirm that it uses an RCA jack or, if not, what connector it does
use.
Second, you need a 75ohm cable with the appropriate connectors. The
easiest is to use a video cable which you can buy at RadioShack as
long as you confirm it is 75ohms.
Will it work? Probably, but 40 feet is a long run from a computer
output which may not be the best driver. Good luck.
Hmm intresting. If the 40 ft causes me problems what about wireless?
Anyone have any experiences using a DMA (digital media adapter)? I
know linksys makes them.
Doesn't Apple make gadgets for this? Airport or some such?
I am guessing your Mcintosh is actually an analog piece in which case
you need a DAC. The Benchmark is one of the most well-thought-of and is
about a thousand dollars. You might also consider a sound card with 600
ohm balanced out and run it to the Mac where it could be converted to
single-ended with a transformer.
If the Mac does have a digital input a converter probably can be had.
A third possibility is a diskless music server which can be hooked up
by ethernet.
DAC meaning Digital to Analog Converter correct? This is a possiblily.
I like the Idea of the diskless music server. Do you have any links I
could check out?
"Clay" <clay_miner@hotmail.com> wrote in message
news:1121809152.232718.10420@o13g2000cwo.googlegroups.com
about
> wireless?
I guess Kalmann has never actually seen SP/DIF work over
long distances. I have.
The SP/DIF standard is not difficult to implment properly
and it frequently is implemented very well. With a good
grade of coax, it will probably work well over 100's of
feet. If you want to be conservative, get highly shielded
(triple or quad-shielded) copper-core RG-6 type coax.
>about
>> wireless?
I wasn't concerned with S/PDIF or the cable but with
the implementation in the undefined output driver of
the Mac since Macs are terra incognita to me
"Kalman Rubinson" <kr4@nyu.edu> wrote in message
news:fh2rd1d1k5oegtn3jd3lk69df3g3gbjp8d@4ax.com
> On Tue, 19 Jul 2005 19:05:24 -0400, "Arny Krueger"
>> about
>>> wireless?
I have a couple of Macs, and their interface circuits are
about as good as anything.
On 2005-07-20 08:39:16 +1000, "Clay" <clay_miner@hotmail.com> said:
> Yeah they do. I'm just curious If I'm going to lose audio quality if
> I'm streaming it over 802.11 instead of a direct digital cable.
The Apple AirPort Express uses Apple Lossless compression when
transmitting the sound to it. So, if you're using a "pure" audio
source, such as a CD, or something compressed with a lossless format,
then you don't lose anything.
If you're playing back MP3s, you don't lose anything above and beyond
what the MP3 compression has already lost you...
I picked this up on the way home from work yesterday and I love it! It
works perfectly with my Dad's 16,000 songs on iTunes and is very easy
to use. He had no trouble navigating to his playlists. I had the unit
hooked up to our wireless network and secure (locked down using MAC
address) in about 20 minutes. Sound quality is great, im very
impressed.
