Tom's Hardware > Forum > Audio > Audio Technology > NEC Power Transistors - need info -
Forum Audio : Audio Technology - NEC Power Transistors - need info -
Archived from groups: rec.audio.tech,sci.electronics.repair (More info?)
Hello,
I'm trying to find the equivalent of two NEC power transistors, it's a
NEC 2SD188A and a NEC 2SB545A.
I need some technical info of those transistors or datasheet? I have
Sasnui receiver and one channel doesn't work. Thanks in advance! Best
Regards!
Zeljko
Sponsored Links
2SD188(A)
Si bipolar NPN TO-3
Vceo = 80 V
Ic = 7 A
Pmax = 60 W
Hfe min./max. = 30 / 120
2SB545(A)
Si bipolar PNP TO-3
Vceo = 70V
Ic = 5,0A
Pc = 60W
Reply to Anonymous
"Zeljko" <no_mail@nospam.com> wrote in message
news:MPG.1d4e1bac814f361a9896e6@news.CARNet.hr...
> Hello,
> Regards!
> Zeljko
**VCBO - 100
VCEO - 100
Ic - 5A
Pc - 50W
hFE - 50 (@4A)
fT - 10MHz
Trevor Wilson
www.rageaudio.com.au
Reply to Anonymous
- 0 +
Dana Sun, 24 Jul 2005 23:14:08 +0200 na news grupi
osoba pod imenom François Yves Le Gal je napisala...
> 2SD188(A)
> Si bipolar NPN TO-3
> Vceo = 80 V
> Ic = 7 A
> Pmax = 60 W
> 2SB545(A)
> Si bipolar PNP TO-3
> Vceo = 70V
> Ic = 5,0A
> Pc = 60W
Thank you guys!! Thank you very much!
Best regards from Croatia!
Zeljko
Reply to Zeljko
Hello,
Regards!
Zeljko
Hi,
I use http://www.datasheetpro.com/ when I need datasheet for any component and it works very well for me. Datasheetpro is a free electronic engineering tool that enables you to locate product datasheets from hundreds of electronic component manufacturers worldwide.
Try it and I hope you will be benefited.
Good luck!
Reply to donald54
There are 581 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
