Archived from groups: alt.audio.equipment,rec.audio.tech,alt.cd-rom (More info?)
Kompu Kid wrote:
> Hello All:
> I am trying to convert my cassettes to CDs.
> I tried to it with the onboard audio circuitry on my motherboard.
> I had terrible results. The converted audio file has a humming
> background noise.
> I have looked at the archives and various Usenet groups, however, did
> not find any person discussing a similar problem.
> I am wondering what I need to do, specifically, which equipment to
> change in my current setup to get a quality audio file.
> Here is a list of the equipment that I am using:
> -- AMD ATHLON 2200 computer, 512 K RAM, SY-KT333 DRAGON Ultra (Platinum
> Edition) motherboard. (Here is more:
> http://www.soyousa.com/products/proddesc.php?id=46 )
> -- On board CMI 8738 providing 6-channel audio
> -- Sony TC-153SD cassette deck (here is an image I found on the
> Internet: http://home.hccnet.nl/piet.blaas/sony.htm )
> I am connecting the cassette deck to the Audio In port at the back with
> the appropriate cabling.
> Any advice is appreciated.
> Deguza
If you have your cable TV signal connected to your PC in any fashion
(e.g. cable broadband, TV card, etc.), try disconnecting it before
recording.
.... sounds like a ground loop to me, and cable is a likely source.
The e-mail address in our reply-to line is reversed in an attempt to
minimize spam. Our true address is of the form che...@prodigy.net.
"Kompu Kid" <deguza@hotmail.com> wrote in message
news:1124599451.813383.15060@z14g2000cwz.googlegroups.com...
> Thanks for your reply.
> I don't have a cable TV signal or broadband connected to the PC.
> However, the computer is not directly connected to an outlet. It is
> connected to a UPS. I wonder if the UPS is the culprit.
> The UPS is then attached to a GFCI type of outlet.
Plug the cassette machine and the PC into the same outlet
(whichever side of the UPS and/or GFCI it is).
news:1124598519.835836.9200@g14g2000cwa.googlegroups.com...
> Hello All:
> background noise.
> however, did not find any person discussing a similar problem.
Hum is a very very common problem.
> (Platinum
Unlikely it has anything to do with the CPU, motherboard,
etc.
On 20 Aug 2005 21:28:39 -0700, "Kompu Kid" <deguza@hotmail.com> wrote:
>Hello All:
>background noise.
I interpret the "humming" as A/C line frequency (50 or 60 Hz depending
on where you live), is that it? If that is the case, try the
following:
It looks like your Sony deck may be run off batteries. Try to do that,
and see if the hum is coming from an unfiltred AC in the deck, or a
ground loop of some kind.
If that is not the problem, try other line sources, such as a CD
player. A ground loop may very well be the problem, but not have an
obvious source. Try disconnecting other peripherals you may have
connected to your computer.
Let's look at this connection in more detail.
The way to get audio from a tape player to a sound card is by
connecting Line Out to Line In. Anything else is a kludge.
Headphone Out is not Line Out. Mic In is not Line In. Before we
worry about ground loops, let's check that the basic connection is
correct.
Are you connecting outlets on the tape player marked Line Out
(probably a pair of phono sockets) to a port on the computer marked
Line In (probably a stereo 3.5mm jack)?
If the tape player doesn't have Line Out, obtain one that does.
> Hello All:
> background noise.
Remove the cable from the back of the computer and record. You should get
nothing.
If so, check to be sure the recorder is plugged into the exact same outlet
as the computer. Not one across the room. That should do the trick.
Report back.
i had similar problems a while back and the way i resolved it was to change
my onboard sound card for a sound blaster live card then downloaded a trial
version of Rip Edit Burn a software program put out by Singing Electrons,i
was very satified with the trial version so i purchased the full version on
line,i am sure there are many other ways of converting tapes to cd but this
one worked for me ,good luck , ken t,nc.
> Hello All:
> background noise.
> Deguza
> it was to change my onboard sound card for a sound blaster
> live card then downloaded a trial version of Rip Edit Burn
> a software program put out by Singing Electrons, i was very
> on line,i am sure there are many other ways of converting
> tapes to cd but this one worked for me ,good luck
It is inconceivable that the recording software could have
anything to do with the presense of hum in the recording.
And very unlikely that the onboard sound card was the
source of the hum, either. More likely in the process of
changing sound cards, the offending input got muted, or
whatever the actual problem was.
> Deguza
A quick experiment would reveal whether the UPS is the culprit.
In alt.audio.equipment,rec.audio.tech and alt.cd-rom, On Sun, 21 Aug
>> Hello All:
Keep your nose clean, don't drink and drive.
>Do recordings on your computer "hum" with other sources
>besides the cassette machine?
>Does the output of the cassette machine sound clean (no hum)?
>Does moving the cassette machine change the hum?
Especially, is it anywhere near a CRT monitor? Move it as far away
from other equipment as the cables will allow.
>Where (exactly) do you have the power cords from the
>computer and from the cassette machine plugged in?
Thanks for all the suggestions and advice.
Additional information on my setup:
- I am not using the headphone outlet on the Sony cassette deck.
- I am using the "line-out" on the cassette deck. This line-out is
similar to the ones I have on my TEAC cassette deck and CD player.
- The "audio-in" port at the back of the computer is smaller in
diameter, probably for a 3.5 mm jack as Laurence Payne said. (I am not
using the port for the microphone. I have my headset's microphone
attached to that.)
- The cable I use is a "Y". The two jacks get attached to the cassette
decks line-out ports. The smaller one to the sound card.
- When I record Internet broadcasts with the computer, I do not get any
hum.
- The tape recorder/player is not close to the monitor, but it was
nect to the UPS. I will try to move it away and see what happens.
However, when I listen to a cassette directly from the deck, I do not
hear any noise.
- My UPS is a large TrippLite with two banks of power outlets. I am
using one back for the computer. The cassette deck is attached to one
of the outlets on the other bank. My recollection is that these two
banks are different in the way they deal with the power. I will connect
everything to the same outlet directly and see what happens.
I will try the other suggestions as well and report on the progress.
> Hello All:
> motherboard.
> humming background noise.
> problem.
It seems like we hear about this problem about once a week,
certainly on some audio group someplace every two weeks or
less.
It's called a ground loop.
Search Google under "ground loop" for more information.
that's odd- I tranfer vinyl and analog tapes to CD-R all the time, no
hum- just using an as-is HP Pavilion with Windows ME and the Music
Match Jukebox that came with it, RCA jacks patch corded into the line
in jack, and set volume to low/moderate listening level.
"66fourdoor" <trippingtoo8track@yahoo.com> wrote in message
news:1124710125.932661.315920@o13g2000cwo.googlegroups.com
> that's odd- I transfer vinyl and analog tapes to CD-R all
> the time, no hum- just using an as-is HP Pavilion with
> Windows ME and the Music Match Jukebox that came with it,
> RCA jacks patch corded into the line in jack, and set
Right, there's nothing that's necessarily troublesome in the
basic idea.
Poor guy has a ground loop, but he doesn't seem to know how
to spell "ground loop". Google pulls up some great articles
on the topic almost instantly, but you gotta know how to
spell "ground loop". ;-)
I do know how to spell "ground loop" -
I just did not know that such a thing causes the hum I am hearing...
Electronics is not my forte, that's why I am posting here to have more
knowledgeable people help me...
well if it turns out that it is not completely the ground loop problem then
more suggestions below.
news:1124664425.300608.201880@g14g2000cwa.googlegroups.com...
> attached to that.)
This is where the **muting** of all other inputs would be useful advice
(from other post tim martin ) ....
maybe your microphone input is generating the hum or possibly you have MIC
boost selected or some other option that is introducing the hum.
I did not see any mention of OS used ? EG. if Win2K then you will want to
select "Volume Control ->Options-> advanced controls"
and then under "Volume Controls->Options->Properties->Playback ",
enable/select all the items under "show the following controls" and then you
can check/experiment with muting various input controls maybe look into any
relevant advanced options
you will also want to check out the "Sounds and Multimedia Properties" of
your audio devices
also you could bring up the "Volume Controls->Options->Properties->Recording
" and make sure while you are trying to record that the proper input
recording device shows as selected
You did not mention the recording software you were using to capture the
audio input ??
Archived from groups: alt.audio.equipment,rec.audio.tech (More info?)
Yeah, I had a similar experience: the air filter in my car was dirty, so
i bought a new car;-)
> attached to that.)
> hum.
> hear any noise.
> Deguza
Holy cow! Headset and mic connected to the soundcard? Dis-connect THAT.
Move evrything away from the UPS. I bet the noise is one of those.
Kompu Kid wrote:
> Hello All:
This should work and provide results that are acceptable in the context.
> background noise.
First question: is the casette OK when listened to?
I am inclined to think that it is the same audio chip as in my K7S5A
mobo, I have used it to make acceptable recordings from a FM tuner, no
reason why a casette deck should be a problem.
Thank you, exact to the point documentation. Age may matter, but ex
works it is a very good machine.
You DID use the line input, you did not make the error of using the mic
input and setting input level very low?
Cabling or level setting has been inappropiate if the result is poor, if
you live somewhere where it is assumed that more earthing leads to more
electrical safety you may have a ground loop issue, Arny wrote something
about this in a similar context fairly recently. As someone else
suggested a simple way of testing is to run the casette deck on
batteries.
The deck just possibly may also dislike being closer than a few feet to
computer and CRT, not something I know, just something I would want to
check.
It can be very practical to use a headphone output, it is not the
shortest route out of the tape deck, but a 6.3 mm jack to minijack lead
is about as simple a connection as it can be, otherwise you need a phono
cable and a dual phono to minijack converter plug.
You did try using another connector cable in case it was a cable fault?
> Deguza
Kind regards
Peter Larsen
* My site is at: http://www.muyiovatki.dk *
