Tom's Hardware > Forum > Audio > Pro Audio > dc-dc converter chip for phantom power
Forum Audio : Pro Audio - dc-dc converter chip for phantom power
Archived from groups: rec.audio.pro (More info?)
Howdy all......:-)
Looking for recommendations for a dc-dc converter (12vdc input/48vdc
output) integrated circuit so that I can roll my own portable phantom
supply.
Found one such beastie at:
http://www.recom-international.com/html/euroline.htm
RxxTR244872 In 5, 12 Out 24, 48, 72
Any others that fit the bill? Thanks! :-)
Sponsored Links
Lawrence Lucier <llucier@shaw.ca> wrote:
>Howdy all......:-)
>supply.
There are plenty of them and they are all evil. I have used the shielded
ones from Endicott Research and they are okay for noncritical applications
where you can live with some RF trash. All of them are going to require
some extensive filtering on both the outputs AND the inputs.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
On Tue, 20 Jul 2004 15:47:49 GMT, in rec.audio.pro you wrote:
>Howdy all......:-)
>supply.
if you want to roll your own, try
LT1533 ultralow Noise1A Switching Regulator from linear.com
http://www.linear.com/pdf/1533f.pdf
martin
Serious error.
All shortcuts have disappeared.
Screen. Mind. Both are blank.
Reply to Anonymous
"Lawrence Lucier" <llucier@shaw.ca> wrote in message
news:F8bLc.63642$Mr4.39806@pd7tw1no
> Howdy all......:-)
> supply.
You might want to take a look at the discrete-component alternatives:
One approach is to run a voltage multiplier off of an existing power
transformer winding,
http://sound.westhost.com/project96.htm
http://www.symetrixaudio.com/tech_ [...] 02_1A0.pdf
http://www.uneeda-audio.com/phantom/phan01.gif
the other is to use a switchmode multiplier running off of an existing DC
supply.
http://www.paia.com/tubehsch.pdf
http://www.rolls.com/data/pb224man.pdf
Reply to Anonymous
That's what's used in AKG PT pocket transmitters, FWIW.
geoff
Reply to Anonymous
On Wed, 21 Jul 2004 21:59:23 +1200, Geoff Wood <geoff@paf.co.nz-nospam>
> geoff
Any reason why you're not thinking linear instead of switching?
Reply to Anonymous
If you are wanting to get 48V from a battery supply, you either need
a lot of batteries or a switcher.
Personally, I tend to go the route of using a lot of batteries.
--scott
Reply to Anonymous
> --scott
Oh BATTERY . .missed that. Four car batteries'd do it. Or perhaps
better four RV "Deep Cycle" batteries. Probably last four-five years.
Reply to Anonymous
I normally use five 9V stacks, which gives you 45V, or six 9V stacks
plus a 48V series regulator (which more than doubles the usable lifetime
if you are using alkalines). It's kind of bulky, though.
--scott
Reply to Anonymous
How about a combination? Rechargeables fed by a dc-dc converter built
to less critical specs?
While 9v rechargeables still aren't good enough to handle most applications,
I would think that a low current demand like phantom power would be
do-able.
Rob R.
Reply to Anonymous
Maybe, but you're still carrying around a big box of batteries. In fact,
since the current demand is so low, even cheap alkalines will last so long
that it's not worth even worrying much about using rechargeables.
--scott
Reply to Anonymous
In that case, why not use one of those 67-volt camera batteries that
looks like a fat AA cell? They sell them at Batteries Plus and
probably Radio Shack. How long do you suppose one of those would last?
ulysses
Reply to Anonymous
In article <290720042320335085%ulyssesnospam@rollmusic.com>,
Not as long. Because they are lead-acid batteries, they have self-discharge
issues so they eventually go bad on the shelf.
I built a supply for the B&K lab mikes using three of them to get the 200V
polarization and plate voltages, and they did well, though.
Oh yes, and they are a little bit bigger than five 9V batteries.
--scott
Reply to Anonymous
- 0 +
In article <290720042320335085%ulyssesnospam@rollmusic.com>, Justin Ulysses Morse <ulyssesnospam@rollmusic.com> wrote:
>ulysses
Small 12v Gellcell batteries hooked together inseries 4x12 to equal your 48V
would do the trick
Reply to Gman
There are 1132 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
