Hi,
I would like to replace my dual fan power supply from my older 1998 Gateway G6-450XL Motherboard #4000402. The model # is listed below. However, I would replace the power supply with one with a higher wattage. I still want it to be a direct bolt in with the proper wire connections. Can you help me? I'm replacing a video card that needs more wattage. Size is 6.5" x 3" x 5.75" or something very close. It doesn't appear to be a standard ATX although the case says it is. And it is making finding one difficult. I tried the ATX ANTEC 330 and its the wrong size. Where can I find a more powerful power supply? Or at least one that is closer to my size. P.S. I don't want to buy a new case!
Gateway # 6500184 POW 200W 5/3A 3.3V W/700MA R5
Thank you, Joseph
Thank you, Joseph
