Tom's Hardware > Forum > Audio > Pro Audio > need advice on speakers to use for sound/art installtion i..
Forum Audio : Pro Audio - need advice on speakers to use for sound/art installtion i..
Archived from groups: rec.audio.pro (More info?)
Hello
I will be preparing a sound/speaker installation for a
hallway/stairwell of a large contemporary art museum. I will need to
put several speakers mounted on (in) the walls on either side along
the hallway, which will be around 2 to 3 feet from the people walking
by. The sounds coming through the speakers will not be very loud, and
they will be sort of abstract/electronic, but I want a nice clear
sound from the speakers.
I would like to know if anyone has suggestions as to what type of
speaker would be relatively inexpensive, the proper size, and right
sound quality for this type of event.
Any thoughts would be appreciated
Thanks so much
Sponsored Links
How wideband is this stuff? Is it going to have a lot of low end and
a lot of top end? Do you care about midrange accuracy?
How concealed do you want the speakers to be?
What is the wall construction? Are these deep walls, or are they narrow
with metal studs? Or is this a load-bearing cinderblock wall where you can
knock a hole in a block here and there.
Does the sound have to be very even in level and effect as you walk down
the hall? Or can it vary?
Are all of these speakers going to be producing the same sound (so that you
will have to worry about phase cancellation between adjacent speakers) or
not?
Have you considered ceiling speakers instead? If so, what is the ceiling
construction like?
Are you going to be trying for any actual stereo effects?
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
oliviablock@comcast.net (livb) wrote in message
You'll probably want to use 8" ceiling speakers, depending on the
bandwidth you need. These can range in price from $10 to several
hundred each, depending on the quality. Something like the $20 pioneer
full ranges (dual cone) would probably be adequate, and would allow
you to do a series parallel hook up to a normal amplifier. Otherwise,
you'll need to do a 70v distributed system.
If you need extended deep bass, it will take a couple subwoofers.
What city is this in?
Greg B
Reply to Anonymous
Tannoy is one of the kings of flush mount speakers. Try here.
http://www.tannoyna.com/commercial/index.html
Reply to Anonymous
Hi
> a lot of top end? Do you care about midrange accuracy?>>
Im not sure yet how wide it will be, but htere will definitely be
midrange, and some lows and highs, although most likely not extreme in
either range. I do want midrange accuracy, definitely.
> How concealed do you want the speakers to be? >>
As much as possible, probably just cones will be visible in the walls?
> knock a hole in a block here and there.>>
This is a good question-I have to find this out, but my guess is that
it is just the regular drywall?
> the hall? Or can it vary?>>
By nature of the sounds themselves it will vary, as the sounds will
sort of float in and out volume-wise, but it would be better if all
the speakers had the same effects for consistency.
> not?>>
Most of them will be producing the same types of sounds with little
variations, although I wont really have to worry about phase
cancellations because the sounds themselves are sparse and have a lot
of space in them, and as I said they will drift in and out. Each
speker will have its own CD source,so all of the sounds miight be the
same, but playing at different times so they will overlap, space will
be between them, etc
> construction like?>
There will be a different type of speaker hanging from the ceiling. I
dont think speakers would have to be mounted in the ceiling, its high
enough where they could be suspended. I had an idea to put some in the
walls and some from the ceiling.
> --scott
No, not really, if I understand your question. I think each L and R
will be a different speaker with a seperate sound assigned to it,
although there may be a panning effect where the sound might drift
from one speaker to another, but not in a stereo spacial set-up, maybe
far from each other. These are good questions, as I am just in the
beginning stages and have just started thinking about the details.
Reply to Anonymous
Hi
> you to do a series parallel hook up to a normal amplifier. >>
When you say parallel hookup do you mean they could all be connected
to one sound source, like one CD player? Sorry if this question is
dumb!
When you say ceiling speakers, do you mean I shouldnt mount them in
the walls at all? Would you recommend the same size for the walls?
What brand is a little better than average but not terribly expensive
and where would I purchase a cone without the casing? Again, probably
stupid questions...Thanks!
Otherwise,
> you'll need to do a 70v distributed system.>>
Can you explain further?
I dont think the bass will be too extensive, although there will be
some, so maybe I dont need the woofers
<<> What city is this in?
Chicago
Thanks!
> Greg B
Reply to Anonymous
This looks promising. Thanks . I am worried about the costs, though. I
couldnt find a price list. Are they expensive? Thanks so much!
Reply to Anonymous
Okay. Midrange accuracy costs money. Extension costs money, but putting
them together costs more than just one.
The Tannoy ICT systems, for instance, have very clean midrange, but not much
top or bottom. The Speco in-wall stuff has a lot more top end bottom but not
very accurate midrange.
For most electronic stuff, midrange accuracy isn't really an issue at all,
at least not like the way it is for vocal stuff. But it's your call.
This affects how deep you can mount the cabinets. You need to find this
out before anything else.
If it's floating in and out then you don't need to worry so much about
pattern control at all and you can live with wider and more sloppy patterns.
It also means you can get away with more distant placement.
>> not?>>
Okay, so they aren't synchronized or coupled. This means there is no issue
at all with phase cancellation and you don't have any issues at all with
speaker pattern whatsoever.
>> construction like?>
Mounting them in the ceiling will allow you to cover broader areas than
suspending them. This may or may not be a good thing for you.
I suggest that before doing anything else you go out and get one of the
cheap 8" installed-sound speakers like are used for paging in your local
supermarket. You can call Cain Electronics in Norfolk, VA and order an
8" driver in a cheap woodgrain cabinet for something like $20. Give
that a listen and take that as your baseline. What do you want that you
can't get out of that?
The high end response on these will drop off very dramatically as you
walk past them, because the drivers are very beamy. They don't have much
top end or much bottom end and they have a couple weird midrange resonances.
Of these problems you need to find out which ones bother you and which ones
you can live with so that you know what direction to start looking in.
--scott
Reply to Anonymous
There are 632 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
