Yes No
Ads
Tom's Hardware > Forum > Home Audio > Pro Audio > Wood Racks and Chassis ground
Forum Home Audio : Pro Audio Wood Racks and Chassis ground
Archived from groups: rec.audio.pro (More info?)
I am racking some audix and telefunken modules in a wood case. Does
anyone have any suggestiuons on what to do with chassis ground. I
don't know if this is dangerous, but I am puting a SPST switch for the
AC line on a MDF front with no connection to ground since it is wood,
as well as other components like pots and audio switches.
Thannks in advance
Reply to Anonymous
>From: cs@guavatone.com (Charles Schaefer)
>Date: 7/23/04 6:07 PM Eastern Daylight Time
>Message-id: <80fadc53.0407231407.1a1d3ad9@posting.google.com>
Are they ungrounded plugs (AC)? If so you can try the old stand by of "tie low
to ground". I'm not all up on your gear so perhaps someone who is will chime
in.
Reply to Anonymous
In article <80fadc53.0407231407.1a1d3ad9@posting.google.com>,
What's wrong with a grounded metal chassis? Why use wood to avoid it?
Regards,
Monte McGuire
monte.mcguire@verizon.net
Reply to Anonymous
In article <80fadc53.0407231407.1a1d3ad9@posting.google.com> cs@guavatone.com writes:
There's nothing wrong with switching just one side of the line, as
long as it's the hot (not neutral) side.
As far as audio goes, you may find that you get less hum if you
connect the chassis to your common audio ground.
As far as safety goes, if there's a connection between the chassis and
safety ground (the third pin on the power cord) you should maintain
that.
Wood racks are good in the sense that you can isolate one chassis from
the other and have only a single audio ground path, but don't forget
the safety aspect.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
In article <monte.mcguire-C795D7.04322324072004@news.verizon.net>,
>Regards,
>Monte McGuire
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
"Monte McGuire" <monte.mcguire@verizon.net> wrote in message
news:monte.mcguire-C795D7.04322324072004@news.verizon.net
>> the AC line on a MDF front with no connection to ground since it is
>> wood, as well as other components like pots and audio switches.
Good point. Ideally, that power switch would be inside a grounded enclosure,
unless the switch itself had no exposed metal surfaces.
Reply to Anonymous
I'm still a bit confused. (No wisecracks, Arny.)
I own an Intra "wooden" rack-mount rack. The cabinet is wood, but there are
metal rails to screw the equipment into. This effectively grounds all the
equipment together. Which can be a good or bad thing, depending. (I've seen it
go both ways.)
I don't understand what the problem is. I find it hard to visualize a wooden
cabinet that a piece of rack-mount gear simply slips into -- or has little
bosses for the screws. To paraphrase Alton Brown -- that's not good mountings.
Reply to Anonymous
On Sat, 24 Jul 2004 08:42:40 -0700, "William Sommerwerck"
Why hard? I can visualise both quite easily - like a nest of
drawers without the drawers.
I'd assumed half the purpose of a wooden rack was to give the user
control over equipment grounding. Or maybe just to be a fashion item
in a contemporary-styled studio (Is wood still "contemporary?)
I used to have an equipment rack with the units hanging vertically off
two wooden runners. No fixings were strictly necessary, but if I
felt the need to locate an item I'd just put in a small wood screw.
CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
Reply to Anonymous
"William Sommerwerck" <williams@nwlink.com> wrote in message
news:10g50ug67654ed5@corp.supernews.com
I hope I didn't contribute to it with my last post!
> there are metal rails to screw the equipment into. This effectively
> grounds all the equipment together. Which can be a good or bad thing,
> depending. (I've seen it go both ways.)
I guess you're saying that the metal rails are electrically bonded together.
Is there a problem?
> wooden cabinet that a piece of rack-mount gear simply slips into --
> or has little bosses for the screws.
I've built them.
To quote someone I know, I don't understand what the problem would be with
that.
Reply to Anonymous
Monte, its a poor man's solution to rackin stuff.
Mike, what do you mean about the safety aspect? this is my caoncern.
Reply to Anonymous
>> I find it hard to visualize a wooden cabinet that a piece
>> of rack-mount gear simply slips into -- or has little bosses
>> for the screws.
> I've built them.
> would be with that.
To clarify -- I'm thinking in terms of overall sturdiness, or not having the
unit slip out. That's all. The electrical aspect is not a consideration.
Reply to Anonymous
I thought I replied but it doesn't show up.
Thanks for all the in depth answers to this.
I basically need something to put the modules and PSU in and I can
make a wood rack ina day or two. a metal one would be big bucks and
timely.
So, If I have a power switch that is metal hooked up to AC-live that
is bad probable since there is no fround connection via chasis on a
metal box?
If I have a plastic switch that may be better right?
Or I could buss the green wire from the 3prong AC to a washer around
the switch. would that make it "safer"?
The power switch is SPST. I was going to use it to break and make the
live connection AC prior to the PSU that is 24VDC for the Audix.
Reply to Anonymous
On 24 Jul 2004 13:42:10 -0700, cs@guavatone.com (Charles Schaefer)
>timely.
Do they have Dexion where you live?
Though wood's nicer :-)
Reply to Anonymous
>go both ways.)
He is building a box that has some old modules stripped out of a console,
with a flat front plate and holes so that it can be mounted into a rack.
He is using MDF for this for some reason, which seems a little weird to me
but not too terrible.
--scott
Reply to Anonymous
>timely.
I dunno, it would seem a lot easier to make a good metal one than a good
wood one. You buy a premade front panel, cut some holes out of it, and
use some aluminum L-bracket to mount the modules.
>metal box?
As long as the switch doesn't fail in a bad way that makes the switch
case live, it's fine. I have not seen that happen before but it could
happen.
You worry too much.
--scott
Reply to Anonymous
>> the live connection AC prior to the PSU that is 24VDC for the Audix.
> You worry too much.
Agreed. But if you're going to switch the line, you should use a double-pole
switch and switch both the hot and neutral. It's safer that way.
Reply to Anonymous
news:10g5cnc11n87qe1@corp.supernews.com
>>> for the screws.
>> I've built them.
>> would be with that.
> having the unit slip out. That's all. The electrical aspect is not a
> consideration.
Oak is pretty strong stuff. T-nuts are pretty tenacious.
Reply to Anonymous
In article <10g50ug67654ed5@corp.supernews.com> williams@nwlink.com writes:
When I had my remote truck, I mounted some rack-mount gear in wood
because it saved space over using rack cabinets. I had a pair of
vertically mounted 2x2s spaced the "gear width" apart, with T-nuts to
catch the screws. Nice and solid, and gave me a couple of extra
inches. I never had a problem with chassis that touched an adjacent
one, or not.
Reply to Anonymous
In article <80fadc53.0407240940.5da9256d@posting.google.com> cs@guavatone.com writes:
I wasn't quite sure what you were really doing. The "safety aspect" is
that equipment in a metal case usually has the case connected to the
electrical safety ground (the third pin on the power plug) so that if
the hot side of the AC touches the case, it will return to neutral
through the safety ground, tripping a circuit breaker on the way, and
the chassis won't be electrically "hot."
If the equipment is in a wooden box so there's no way you could touch
the chassis, then it's safe. However, if the chassis is connected,
either throgh rack rails or through a cable shield, to another
chassis, then that other chassis could become AC-hot in the event of a
short in the "insulated" chassis.
Portable power tools and home appliances are often "double insulated"
and have no safety ground. There's no way you can contact anything
that the hot AC lead can touch, so there's no risk of electrical
shock. And, plastic being cheaper than copper, this is a way to save
money.
Reply to Anonymous
In article <80fadc53.0407241242.3c32c7c8@posting.google.com> cs@guavatone.com writes:
> timely.
> metal box?
Why not just use a switched outlet strip? They're cheap, UL approved
(safe) and you need a place to plug all that stuff in to anyway.
Reply to Anonymous
> Why not just use a switched outlet strip? They're cheap, UL-approved
I was once warned by a fire inspector about cheap outlet strips. It seems their
circuit breakers can actually _cause_ fires.
The reason? Some cheap breakers have a fairly high resistance. If you pull
enough amps through them (though not enough to trip the breaker), the breaker
will overheat and burst into flames.
I hate it when that happens.
Note that this is not an inherent problem with circuit breakers (per se), but
with badly designed or manufactured breakers.
Reply to Anonymous
In article <10g60nmaj09uiae@corp.supernews.com> williams@nwlink.com writes:
So buy a better one. Anything that's UL approved isn't a fire risk.
The risk with outlet strips is that they use a varistor for surge
suppression. Each surge that it suppresses weakens the component, and
eventually it won't be a surge suppressor any more. Seems like I
remember that some of the surge suppressor outlet strips from 20 years
ago were reported to arc over, but I haven't heard about that in
years.
Besides, fire inspectors get worried about things like this that, in a
typical home, get stashed behind a couch or bookcase, possibly with
curtains hanging directly over it, and nobody looks at it for 20
years. That's a fire hazard.
If you get an approved outlet strip and mount it on the back of your
wood cabinet where you can reach the switch, you'll have no problem.
Reply to Anonymous
>years.
There was a serious problem about a decade ago with a particular series
of SL Waber power strips (NOT surge suppressors) which were unfortunately
supplied by Rolm along with their telephone systems. The internal connections
were poorly crimped, and could present a fire hazard. The solution to this
is to pop the back and solder all of the crimped lines on the back of each
outlet. But again, this was a manufacturing defect and not at all a problem
with the idea of power strips.
--scott
Reply to Anonymous
My understanding is that solder is not used in electrical connections
because of the possible heat these line can see. If they get hot and
the solder melts bigger problems will occur. I think perhaps a better
crimp or wire nut should be used.
>>years.
> --scott
Reply to Anonymous
Ever seen a wire nut? Billions of them have been used over the past 75 years.
Quite reliable.
Reply to Anonymous
There are 1503 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
