I have seen a few similar posts about this problem already on the message boards.
Currently my friend is running winXP on his systems and it is running fine with only the one stick of 128 SDRAM. However installing a seecond stick of exactly similar 128 SDRAM into the board cause errors on windows bootup. It makes it to the windows splash screen and then simply dies and reboots itself.
As far as I can see there is little problem with the ram as we have used both seperatley to boot WinXP fine. However the addition of the second stick causes all of the problems.
We have also tried all different combinations of the RAM in the motherboard and nothing has worked.
I am by no means a guru on XP as this is my first use of the new XP OS but surely the addition of RAM surely shouldn't cause errors like this.
If anyone can shed some light on the problem and possibly some kind of fix it would be greatly appreciated. Sorry about the shortage of system specs....
MoBO: Gigabyte (GA-6BX7) Intel 440BX AGP SET
CPU: Intel P3 733
CPU: Intel P3 733
