Latest Reviews & Articles
Overclocking Core 2 Duo: Power Versus Performance
Intel's fastest Core 2 Duo, the E8600, runs at 3.33 GHz. But if you're a performance-hungry power user, we found that you can actually increase the chip's efficiency by overclocking it, thanks to 45 nm manufacturing and plenty of built-in headroom. Read more
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
All the Reviews & Articles
Tom's Hardware > Forum > Audio > Pro Audio > FS: Alesis Matica 900 Power Amp
Archived from groups: rec.music.makers.marketplace,rec.audio.pro (More info?)
2-Channel Operation:
270W/CH @ 8-ohm
450W/CH @ 4-ohm
680W/CH @ 2-ohm
Bridged Operation:
900W/CH @ 4-ohm
1350W/CH @ 8-ohm
Slew Rate: 80v/mS
SN Ratio: 103dB
Total Harmonic Distortion: .009%
2-Space Rack Chassis
LED Power And Level Indicators
XLR & 1/4" TRS Balanced Inputs
5-Way Binding Post Outputs
48 lb.
$325 + shipping
chasewillett@hotmail.com
There are 835 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
