I've read about people using a speaker as a kick mic in the studio.
Have any of you guys tried this, and if so, how did you like the
results compared to a mic? I'm guess you need a lot of gain for this
to work. Does a larger speaker work better than a small one, or is a
large speaker not sensitive enough? Seems like a large speaker would
pick up more low end. I have a 12" & 10" speakers both mounted in
cabs that I could use for this application.
I like a 4" 45-ohm intercom speaker _because_ it doesn't pick up much
low end. The point is that you get a huge amount of distortion added,
which gives you a very well defined kick sound but without a lot of
real bass that is hard for a home system to reproduce.
Johnny says my box makes kick drums sound like a ping-pong ball. If
you want something with more low end, you can either use a larger
speaker or (more effectively) a larger cabinet.
If you use an 8 ohm speaker, you will probably need to shunt it so it
doesn't ring too badly. A 45 ohm speaker seems happy with a typical
mike preamp input.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
In article <kr1bg09s1hbmfu6p407uoa89pu3o9qcbaq@4ax.com>,
> Al
On Tue, 27 Jul 2004 10:19:05 -0500, another viewer <toomuch@spam.net>
>> Al
>Auratone.
don't forget to wire it backwards because you're using it backwards from
it's intended purpose.
jep
"playon" <playonATcomcast.net> wrote in message
news:l89dg0t2722v1a5hm6q9i51001upjjt1oq@4ax.com...
> >> Al
> >Auratone.
> I knew I should have kept those...
>Message-id: <gNANc.15996$iK.10782@newsread2.news.atl.earthlink.net>
>jep
In article <20040727193320.00126.00000505@mb-m10.aol.com>,
> >jep
> What?
corialis effect, unless you're in the southern hemisphere
playon wrote:
Paul McCartney tried a speaker as a bass-amp mic once. Te technical
assistance evidently got hauled over the coal for allowing an 'impedance
micmatch' . Things like that were important in those days.
I have used a 5" speaker mounted slightly off centre in a wheel of foam plastic as a mic inside a Tama 22" bass drum. It is OK but not as good as a genuine mic .. bu only when used as a recording mic, in other words with no active speakers in the vicinity, because it tends to ring round (positive feedback) when the level is turned up. I suspect that there is much more technology in the air passages inside a professional mic than is ever disclosed to the public.. this is the craft of the manufacturers which allows a cardiod pattern and high rejection of sound not wanted by the engineer. Physical selectivity and this is never an issue with a speaker design.
Joh Screaming Doc hansen.
