>From: fmzep@aol.com (Frank Mazzola)
>Date: 7/27/04 10:47 AM Eastern Daylight Time
>Message-id: <49b94fcf.0407270647.5f335a2e@posting.google.com>
>Is there any advantage/disadvantage among various soundcard
>interfaces, i.e., PCI, USB, or Firewire?
>Thanks
I may be wrong but I belive that Firewire is faster than the normal USB, many
core systems use PCI. Most of the 1-8 input systems use a plug (USB, Firewire)
of somesort rather than a PCI. What is it you want to do?
In article <49b94fcf.0407270647.5f335a2e@posting.google.com> fmzep@aol.com writes:
Sure, but a certain characteristic might be an advantage in once case,
a disadvantage in another case, or a "don't care."
If your computer doesn't have a Firewire port, then a Firewire sound
card would be a distinct disadvantage. Of course you could always add
something to the computer, but then you have two interfaces to futz
with.
For a plain ordinary desktop computer, I'd go with a PCI interface.
For portable multitrack use, I'd go with Firewire (because it's about
the only thing that has a proven track record for doing the job). If
you're looking at portable 2-channel recording, USB is OK.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
>For raw performance, little can beat PCI.
>For convenience, pick USB.
>Firewire is someplace in-between or perhaps the best of both - almost
>PCI-like speed, and almost USB-like convenience.
"Laurence Payne" <l@laurenceDELETEpayne.freeserve.co.uk> wrote in
message newsrodg01uo4lrqvvu9juoi2k3n9co49a6da@4ax.com
> On Tue, 27 Jul 2004 13:43:26 -0400, "Arny Krueger" <arnyk@hotpop.com>
> How is Firewire less convenient than USB?
"Mike Rivers" <mrivers@d-and-d.com> wrote in message
news:znr1090954138k@trad...
Of course USB2 muddies that distinction, but otherwise I agree.
And yes Firewire has a track record which USB2 is yet to establish.
In article <4107309e$0$16107$afc38c87@news.optusnet.com.au> TonyP@optus.net.com.au writes:
I suspect that, at least for audio devices, Firewire will continue to
lead until both USB2 and Firewire are obsolete (sooner than you'd
like).
I can recall only one USB2 multi-channel audio interface (Edirol) and
there may be another one but there are many Firewire interfaces. USB2
seems to be making headway for outboard disk drives and flash memory.
"TonyP" <TonyP@optus.net.com.au> wrote in message
news:4107309e$0$16107$afc38c87@news.optusnet.com.au...
At least one reliable source has suggested that while *peak* transfer
rates for USB2 and Firewire are similar, Firewire delivers much higher
*sustained* transfer rates. Anyone have any data to either support or
debunk that claim?
"It CAN'T be too loud... some of the red lights aren't even on yet!"
- Lorin David Schultz
in the control room
making even bad news sound good
In this place, Lorin David Schultz was recorded saying ...
> debunk that claim?
Can't lay my hands on any data but the Firewire protocol contains a
guaranteed isochronous delivery mechanism that USB lacks. This alone
makes it a much better candidate for transmission of streamed data such
as audio.
I don't want to quote figures since it's too long since I looked at the
specs but IIRC, the message response timing of USB is also much slacker
than Firewire with consequent deleterious effect on sustained bandwidth.
Also, IIRC, USB continues to place a higher burden on the host CPU than
Firewire - I may be wrong on this point so feel free to put me right.
Just my two penn'orth
George
Newcastle, England
Problems worthy of attack
Prove their worth, by hitting back [Piet Hein]
> debunk that claim?
Duuno , but it may end up like a VHS v. beta thing. 90% of what you see in
computer shops today is USB2 (not specifically audio-orientated stuff- just
generally), hardly ever Firewire.
In article <EB_Oc.1273$zS6.160050@news02.tsnz.net> geoff@paf.co.nz-nospam writes:
That's becasue 90% of what you see in computer shops is for a PC, and
Firewire is still more of a Mac thing. Actually Firewire is more of a
video thing than anything else and Macs are still ahead in that area,
at least in marketing.
Most of the USB2 devices that I see are those flash memory sticks. USB
printers are all USB1.1, as are mice and keyboards. It probably makes
sense, if you're going to use an external disk drive (hard disk or
CD/DVD) to use the fastest interface available, and to (still) most PC
users, that's USB2.
> as audio.
>> you see in computer shops today is USB2 (not specifically
>> audio-orientated stuff- just generally), hardly ever Firewire.
That would still make it around 90% then, overall ?
In this place, Eric Desrochers was recorded saying ...
> > as audio.
> Indeed! See : http://mackido.com/Hardware/USB2.html >
Thanks for that.
George
Newcastle, England
