Good afternoon,
I'm currently trying to connect two computers together using a crossover cable. No router, modem or switch. But the damn thing just won't work.
The set up:
Desktop (windows 7) and laptop (also, windows 7) are connected via the cable in their ethernet ports.
Desktop IP = 192.168.2.1
Desktop subnet mask = 255.255.255.0
Desktop gateway = 192.168.2.2
Desktop DNS = 192.168.2.2
Laptop IP = 192.168.2.2
Laptop subnet mask = 255.255.255.0
Laptop gateway = 192.168.2.1
Laptop DNS = 192.168.2.1
(the gateway and DNS being the opposite computers IP is the only way I could get the networks to identify and become home networks)
The problem:
Both computers say they are connected to a network (although different network names, but maybe that's just choices set on the computer) when the cable is plugged in, but neither can see each other, ping each other or recognise if I make a homegroup on either computer. Both computers networks disappear if I remove the cable. I cannot find any shared folders at all. I cannot type in \\NEMO or \\MOSCHETTI (the computers names) as it will not find it.
Network diagnostics on my desktop come up with "your broadband modem is experiencing connectivity issues" and "the connection between your access point, router, or cable modem and the internet is broken" but I do not have a modem at all. I think that might be it analysing the wireless instead of the ethernet, which is not available for use anyway.
While trying some different things on the computer \\NEMO has shown up in the network section of the other computer. Only to get my hopes up, be clicked on, and then come up with an error about not being found.
I have tried a few different solutions I've found on the internet, but I'm willing to reiterate any of them if you have recommendations.
Thanks for any and all help.
The set up:
The problem:
