Netgear WNR1000v3 Connection Issues
Hello,
I recently acquired a new Netgear wnr1000v3 router. I set it up and all cabled computers can access the internet perfectly. None of my wireless devices can connect to it unfortunately. I've tried a number of options to work around this, but I've had no success. I would really appreciate any suggestions that the community might have in resolving this matter. I am trying to connect a Nintendo DS, Nintendo Wii, Xbox 360, Playstation 3, and an Amazon Kindle. Thanks in advance!
6 answers Last reply
More about netgear wnr1000v3 connection issues
  1. type ine the default ip adress put in the user name and password. check to see if the wireless is on if it is make sure its not set to wireless n mode only. i had mine set to wireless n only for security purposes and my room mate could nopt connect any of his game consoles. if that doesnt work hold the rest button for 45 seconds and reset your security settings.
  2. I have checked for what you asked, and I do not see an entry giving the option to change to wireless b, g, or n. I see a "mode" that can be set to 54 Mbps, 72 Mbps, or 150 Mbps. Any other suggestions would be appreciated.
  3. based on your other post it sounds like you believe your router to be defective as you are looking for a new one.
  4. go to your internet browser type routerlogin.com a window will pop up askin for user name and password the username:admin and password:password then you click on wireless on the left then you she see mode and it says 150 mbps chance it to 54 and then change you interney type to WEP and it should pop up on your game systems
    I have tried this and it still will not work. A laptop will connnect, but cell phones refuse to connect no matter what I do it seems.
  6. User manual: http://www.downloads.netgear.com/files/GDC/WNR1000V3/WNR1000v3h2_UM_21OCT2010.pdf
    Follow instructions for factory reset, and then setup again. (Page 100).
    Setup guide if you want a shorter document: http://www.downloads.netgear.com/files/GDC/WNR1000V3/WNR1000v3_SM_24SEPT2010.pdf
Connectivity Connection Netgear Wireless Networking
