ideal sound level for recording wavs
Last response: in Home Audio
Anonymous
August 2, 2004 3:26:11 AM
Archived from groups: rec.audio.pro (More info?)
i'm getting agrivated. I use wave lab lite to record wavs from my vcr or dvd
player
i have a terra tec sound card so i can adjust the gains of the ins and outs
The levels are not supposed to max out and go into the red right?
yellow at the most.
I think the peak is around 3-6 db.
But when i record, the volume of the wav file comes outextremely low
not nearly as high as a wav file ripped from a music cd.
So I boost the db level on the whole thing and it comes out distorted a little.
Anonymous
August 2, 2004 3:26:12 AM
"KnightRdrX" <knightrdrx@aol.com> wrote in message
news:20040801192611.13589.00002578@mb-m12.aol.com...
dvd
> player
outs
> yellow at the most.
little.
Maybe try checking the audio options in windows (if thats your os) & max
levels there as well. also instead of boosting db level try normalize. i
dont know if wl lite has this but the regular wavelab does.
-a
Anonymous
August 2, 2004 11:13:42 AM
In article <20040801192611.13589.00002578@mb-m12.aol.com> knightrdrx@aol.com writes:
Right.
Where are you boosting the level? You may be overloading something
outside the sound card and making a clean recording of a distorted
signal.
CD audio is processed in ways that's designed to make it sound loud.
Audio from other sources, even if it has the same PEAK level, probalby
has a lower AVERAGE level and therefore won't sound as loud.
Learn to use one of the nearly forgotten controls that you have in
front of you - the PLAYBACK volume control. If your recordings aren't
loud enough for you, turn them up when playing them back.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
