can't connect to gprs with mc35!! help!!
  • Siemens
  • Connection
Last response: in Brands
Anonymous
July 12, 2004 11:20:50 PM
Archived from groups: alt.cellular.siemens (More info?)
Hello!!
i'm new one here and not so skilled about all the stuff with GPRS modems so
please can you tell me what I should do to connect to GPRS network using
GSM/GPRS modem Siemens mc35??
i have AT commands dedicated to this device but even though i'm not able to
get connected.
the sequence of commands that I type is:
at+cpin= xxxx
at+cgatt=1
at+cgdcont=1,ip,"apn name" ( i also tried with ip address: =1,ip,"apn
name",xxx.xxx.xxx.xxx - because i have SIM card with static IP address.
at+cgact=1,1
and now what should i do??? i'm typing this:
at+cgdata=ppp,1 ... but after some time i get response: NO CARRIER
the same is after atd*99#
what's wrong??
finally i need to comunicate between two computers using GPRS modems.
i'd be really gratefull if you answer anything to this question.
greetings to everybody here ;)
Greg
More about : connect gprs mc35
Anonymous
July 15, 2004 10:54:58 PM
"G." <kaluckig@tlen.pl> wrote in news:ccuh9g$4v0$1@news.onet.pl:
> Hello!!
> modems so please can you tell me what I should do to connect to GPRS
> network using GSM/GPRS modem Siemens mc35??
> able to get connected.
> at+cpin= xxxx
> at+cgatt=1
> address.
> at+cgact=1,1
> what's wrong??
> Greg
does your phone really have GPRS becouse I think
only x45 and newer models had it
Anonymous
July 16, 2004 3:25:03 AM
yes - "it" (this is modem not phone) has the GPRS mode.
November 7, 2011 7:11:30 PM
Hello!!
get connected.
at+cpin= xxxx
at+cgatt=1
at+cgact=1,1
what's wrong??
Greg
This answerd comes quit late but it's better late than never !
Hi
The AT command AT+CGDATA=1 is supposed to activate all what is needed in your GSM to
make an attachement procedure as GPRS. ( Otrherwise, do AT+CGATT=1, AT+CGACT=1, and dont forget to set the APN name with AT+CGDCONT+....)
From there, the MODULE (gsm module or gsm phone) send you some frame because he try to
negociate some parameterswith you to get the connection working properly.
You see a the reply like ~ }#À!}!}!} }6}!}$}%Ü}"}&} } } } }'}"}(}"}#}$À#&´~
It is ASCII characters who can bee converted in Hexadecimal. All the documentation about internet frames are explained in hexa. As an example, if you convert the above frame you get
7EFF03C02101010016010405DC020600000000070208020304C02326B47E
this is an LPC frame decoded as here below:
7E : StartFlag
FF : addr
03 : controle
C021 : protocole LCP
01 : code Configure-Request
01 : identifier
0016 : Frame lenght
01 : option MRU
04 : option lenght
05 : data
DC : data
02 : option ACCM
06 : option lenght
00 : data
00 : data
00 : data
00 : data
07 : option Protocol Compression
02 : option lenght
08 : option Address and Control Field Compression
02 : option lenght
03 : option Authentication Protocol
04 : option lenght
C0 : data
23 : data
26B4 : Frame Check sequence
7E : end flag
