Tom's Hardware > Forum > Audio > Pro Audio > Power cords for Dolby 360/1?
Forum Audio : Pro Audio - Power cords for Dolby 360/1?
Archived from groups: rec.audio.pro (More info?)
The saga continues.. the Dolby 360 units I got off ebay come without the
power cords. These don't have a standard IEC connector in the back, and
I'd prefer not to modify them if I can avoid it. Their connector is
three reasonable-sized pins, spaced about half an inch apart, in an
oval-shaped recess. It's clearly the precursor to the modern IEC
connectors.
The circuit diagram mentions an "AC3G" part, which seems to have been
once made by switchcraft. I'm not sure if that's the right part, and if
it is, whether that refers to the cord or to the connector.
Anyone have any leads (hah) where to find the appropriate cord or
adapters?
Jay Levitt |
Wellesley, MA | Hi!
Faster: jay at jay dot eff-em | Where are we going?
http://www.jay.fm | Why am I in this handbasket?
Sponsored Links
In article <MPG.1b7cc27616dea0ff9897d3@news-east.giganews.com> jay+news@jay.fm writes:
> connectors.
This is a connector that was most common on business machines (adding
machines, typewriters, ect. in the '60's and you can usually find a
replacement cable at a shop that services such equipment. Although I'm
not sure it's still being made, it's in my older Belden catalog in two
versions:
17280 - "Standard" electrical polarity between plug and chassis socket
17952 - Hot and neutral reversed from standard
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
>connectors.
This is the same cable that HP test equipment used. You might also try
a vacuum cleaner dealer.
Belden used to make them, and Belden's cord division is now owned by Volex,
at 800-246-CORD.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
kludge@panix.com (Scott Dorsey) wrote in message news:<cf029o$p6b$1@panix2.panix.com>...
> >connectors.
> at 800-246-CORD.
> --scott
> You can order them through Dolby Labs in San Francisco. It will be sent to you from England.
I bought 2 M-16 Dolby A racks off Ebay 3 years ago with no power cords
and Dolby Labs had them available.
Good Luck.
R. Morrow
Purely Analog
Reply to Anonymous
In article <znr1091790697k@trad>, mrivers@d-and-d.com says...
Thanks, Mike, Scott, Richard. A local typewriter repair shop had one
sitting in a box of power cords, so I can at least try the gear (it
works!), and with those part numbers I found that Electricord still
makes a compatible cable assembly (ECM-280).
Jay Levitt |
Wellesley, MA | Hi!
Reply to Anonymous
There are 612 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
