Hey guys i recently bought a new gaming rig for myself.
the specs are as follows:
Core i5 2400 3.1 GHz
ASUS P8Z68 VLx Mobo
8 GB DDR3 Kingston Hyper X
ASUS HD7850 DCUII 2GB
1TB WD Blue
600W Great wall 80+ modular PSU
lite on dvd burner
D-link DWA 525 wireless Pci-e card.
cooler master USP 100
23" Phillips monitor
My apt has only wifi and no ethernet connection also i can only connect one component as only one is allowed per room.
My wifi card usually works very good with downloading speeds of @ 1MBps but as soon as any game is launched or i start to watch a movie stored on my hdd the speed suddenly goes down and many a times it disconnects, this is also happening when i launch a you tube video.
But as soon as i close the game or movie or youtube video i regain my speed instantly or if its disconnected it gets connected.
I have checked the power requirements of my config on various sites and it is around 450W so i have enough headroom in case of PSU. so what really is the problem i am not able to understand.
Also discovered one thing if i connect my monitor via motherboard display out i can surf youtube and watch movies from my hdd but during online gmaing my ping is incredibly high upto 500ms . but this is not the case if i connect to my gfx card, on which the connection drops as soon as i do any of the above mentioned work.
Can anyone pls help?????
Ive already posted this on homebuilt and networking general discussion.
http://www.tomshardware.com/forum/forum2.php?config=tomshardwareus.inc&cat=42&post=40252&page=1&p=1&sondage=0&owntopic=1&trash=0&trash_post=0&print=0&numreponse=0"e_only=0&new=0&nojs=0
there has been some great inputs by jgutz but i havent been able to solve my problem completely.
Also have tried ASUS N 13 usb adapter which sucked bigtime!!!!!
So can this be solved with my current setup ???
if not pls recommend me what to buy?
Also refer this site (http://www.invadeit.co.th/) if want to recommend something to buy!!!
ASUS P8Z68 VLx Mobo
1TB WD Blue
lite on dvd burner
