Just made a new build hooked it up to the router, with no problems however when I plug the Ethernet into the powerline, there is only an unidentified network available which I cannot access internet through. As my computer is upstairs I can't root it from the router to the computer so I need the powerline to work. If it helps the powerline was free with the bt infinity (Simpler networks).
Thanks
Thanks
