Archived from groups: rec.music.makers.percussion,rec.music.makers.marketplace,rec.audio.marketplace,rec.music.makers.synth,rec.audio.pro (More info?)
Roland Electronic Drums (3) PD-31 Pads + Tama Stand
This auction is for three (3) Roland PD-31 drum pads, each one has a
center main trigger surface plus three side rim trigger surfaces for a
total of 4 triggers per pad. With just 3 pads you have access to 12
different sounds!!! There are four 1/4" trigger inputs per pad, which
can be hooked up to any standard drum module such as the Alesis DM5.
Also included in this auction is a Tama tom stand which all three pads
can be attached to.
