Tom's Hardware > Forum > Audio > Pro Audio > hard drive recording and drive speed
Forum Audio : Pro Audio - hard drive recording and drive speed
Archived from groups: rec.audio.pro (More info?)
I've got a laptop computer iwth a 4200 rpm hard drive. THis seems standard
for laptops. Digidesign suggests and external firewire drive for use with
their protools stuff (mbox, etc.)
I've recorded video directly from my camera on to the computer and it seemed
OK. I can't imagine just audio needing a faster drive.
If I'm only doing a live 2 track recording, am I taking a chance without an
external drive? Is it just ProTools LE that requires the faster drive?
Sponsored Links
"Dennis Herrick" <herrickd@huntingdon.edu> wrote in message
news:10i05mv2nv3d73b@corp.supernews.com...
seemed
an
Ignore the bullshit, an internal 4200 drive will be fine for 2 channel
recording even at 24/96.
In fact what you don't want is an external FW drive and an external FW audio
interface.
TonyP.
Reply to Anonymous
On Mon, 16 Aug 2004 15:50:08 +1000, "TonyP" <TonyP@optus.net.com.au>
>interface.
You probably do want the audio interface. Laptop sound systems are
rarely more than basically adequate, if that.
A 4200 drive is technically able to do the job. But the laptop will
be full of tricks concerned with power economy - particularly when
running on batteries. make sure these don't get in the way of
performance.
I think it's common experience that laptop performance is noticeably
more sluggish than desktop, even with comparable specs and
non-disk-intensive operations.
CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
Reply to Anonymous
"Laurence Payne" <l@laurenceDELETEpayne.freeserve.co.uk> wrote in message
news:l4v0i0hk5p4471d8v6dln8sj72fl4tahjl@4ax.com...
> >In fact what you don't want is an external FW drive *and* an external FW
audio
> >interface.
Which is exactly why you don't want to use the same channel for an external
hard drive. Lap tops rarely have two FW channels.
TonyP.
Reply to Anonymous
On Mon, 16 Aug 2004 19:52:38 +1000, "TonyP" <TonyP@optus.net.com.au>
>audio
>> >interface.
Ah yes. Sorry, I misread your point.
I was recently shot down in flames elsewhere for suggesting this :-)
I'd experienced problems with Firewire video capture to a Firewire
external drive. Capture to internal drive - OK. Playback from
Firewire drive- OK. Both at once - not OK. But this was apparently
against the rules and couldn't be happening :-)
Reply to Anonymous
In article <10i05mv2nv3d73b@corp.supernews.com> herrickd@huntingdon.edu writes:
Your laptop is fine for 2-track recording, as long as you don't try to
push it beyond 48 kHz 24-bit. You might be able to get away with
96 kHz recording, but if you're going to be making CDs, you might as
well stick with 44.1 kHz.
You'll do well to use something other than the computer's own audio
hardware. The sound cards built into laptop computers are almost
universally ugly. There are plenty of modestly priced USB interfaces,
Firewire interfaces are a little more expensive and probably not of
any tangible benefit at the 2-track level (though the Metric Halo devices
are reported to have particularly nice mic preamps). There's even a
good PCMCIA audio card, the Digigram VX Pocket (I have one of
those) but it's a little more expensive.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
In article <10i05mv2nv3d73b@corp.supernews.com>,
herrickd@huntingdon.edu says...
(IBM)Hitachi are making 7200rpm laptop drives.
/ Peter Kaersaa
Reply to Anonymous
<Peter Kaersaa> wrote in message
news:MPG.1b8c08f2e7ef1c7aab@news.stofanet.dk
>> standard for laptops. Digidesign suggests and external firewire
>> drive for use with their protools stuff (mbox, etc.)
You can also get the effect of a faster drive by simply upgrading to a far
larger drive. This is often more economical. A lot of laptops are out there
with 6-12 GB drives. Upgrade them to 4200 rpm, 60 GB, and with the same data
they will *fly*.
Reply to Anonymous
On Tue, 17 Aug 2004 07:30:41 -0400, "Arny Krueger" <arnyk@hotpop.com>
>they will *fly*.
Because they're bigger? Or because HD technology, even for slower rpm
drives, has improved since the days of 12GB drives?
Reply to Anonymous
message news:bd24i01sr8uiq5u8hkunjvgiug2ndinf9n@4ax.com
>> a far larger drive. This is often more economical. A lot of laptops
>> are out there with 6-12 GB drives. Upgrade them to 4200 rpm, 60 GB,
>> and with the same data they will *fly*.
Yep - bits are more dense, given motions get you a lot more data.
yes, but what really improves the fastest? Answer - recording density.
Reply to Anonymous
"Arny Krueger" <arnyk@hotpop.com> wrote in news:bLWdnYhNO7EHlr_cRVn-
jw@comcast.com:
And the block sizes are larger, grabbing more data at a time with fewer
seeks.
Reply to Anonymous
Well, that's fast. How is the power consumption?
A few months ago, when I shopped for a replacement drive for my Korg
D1200 (the Maxtor Fireball 3 that it came with gets uncomfortably warm
at times), I came up with this:
<http://www.seagate.com/cda/products/discsales/marketing/detail/0,1081,594,00.html>
I thought that the "Momentus" on an adapter (the Maxtor is not a laptop
drive) would solve all my heat (and noise, the Fireball 3 is quiet, but
still audible) problems. Unfortunately I lost my "day" job before I got
around to making the purchase, so I can't report on how it worked. But
it looks like a nice drive, from the specs.
If it was my laptop, I would compare the Seagate and Hitachi at least,
paying close attention to power consumption and noise.
In case anyone is wondering...
I solved the heat (but not the noise) problem on the Korg by setting a
small fan next to it and directing air underneath.
Phil Nelson
Reply to Anonymous
There are 738 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
