Adobe reader x, read out loud doesn\'t work.
The "read out loud" feature will not work on my Adobe Reader X. It loads, and acts as if it should work, but I cannot hear anything. There are NO issues with my computer's audio. Does anyone have a fix for this?
:cry:
5 answers Last reply
More about adobe reader read loud doesn work
  1. Is the text recognised?
  2. Yeah, unfortunately this happens when PDF's are not tagged properly or something, if you have acrobat X you can repair the PDF somehow...
    "PDFs can be made accessible with Acrobat Professional. If you do not own Acrobat Professional, one way to do a quick accessibility check is to try the document with the “Read Out Loud” feature in Acrobat Reader, which can be found under View > Read Out Loud > Activate Read Out Loud , for further details see WebAim's Read Out Loud article. If the document will not “Read out Loud” it may be that the document language has not been specified (see Language page) or that the text is actually an image. " from Univ. Aberdeen
    Something about setting the language, it all seems far to involved just to hear a crappy robo-reader.
    Fungi
    Also you could try freOCR to convert the image to text but it only lets you save as word or txt files... not pdf (and the free consumer software is all cr@p)
  3. Found the instructions for TAGing the PDF in Acrobat, maybe the demo will work? WITHOUT TAGS IT WILL NOT READ OUT LOUD
    Improve the accessibility of PDFs by adding tags in Acrobat. If a PDF doesn’t contain tags, Acrobat attempts to tag it automatically when users read or reflow it, and the results may be disappointing. With a tagged PDF, the logical structure tree sends the contents to a screen reader or other assistive software or hardware in an appropriate order.
    For best results, tag a document when converting it to PDF from an authoring application. Examples of these applications include Adobe FrameMaker®, Adobe InDesign®, Microsoft Word, or OpenOffice Writer. If you do not have access to an authoring application that can generate a tagged PDF, you can tag a PDF any time by using Acrobat.
    Tagging during conversion to PDF requires an authoring application that supports tagging in PDF. Tagging during conversion enables the authoring application to draw from the paragraph styles or other structural information of the source document to produce a logical structure tree. The logical structure tree reflects an accurate reading order and appropriate levels of tags. This tagging can more readily interpret the structure of complex layouts, such as embedded sidebars, closely spaced columns, irregular text alignment, and tables. Tagging during conversion can also properly tag the links, cross-references, bookmarks, and alternate text (when available) that are in the file.
    To tag a PDF in Acrobat, use the Add Tags To Document command. This command works on any untagged PDF, such as one created with Adobe PDF Printer. Acrobat analyzes the content of the PDF to interpret the individual page elements, their hierarchical structure, and the intended reading order of each page. Then, it builds a tag tree that reflects that information. It also creates tags for any links, cross-references, and bookmarks that you added to the document in Acrobat.
    The Add Tags To Document command adequately tags most standard layouts. However, it cannot always correctly interpret the structure and reading order of complex page elements. These elements include closely spaced columns, irregular text alignment, nonfillable form fields, and tables that don’t have borders. Tagging these pages by using the Add Tags To Document command can result in improperly combined elements or out-of-sequence tags. These issues cause reading order problems in the PDF.
    Fungi
  4. I am dl'ing Acrobat and I'll let you know how difficult it is...
    Fungi
  5. Hi
    Its actually much easier than I thought.
    1 Open Acrobat Pro 10 (demo)
    2 Try to use the READ OUT LOUD
    3 It will ask you if you want to try to repair the document, go ahead, it may take a while for big books.
    4 Either it will work or not ....
    Have fun
    Fungi
Adobe Reader Computers Audio Windows 7
