Static ip network, need wireless devices to use DHCP
Hello. I have a static network with nodes connecting to a firewall at 192.168.1.1. The nodes are in the 192.168.1.x network with subnet 255.255.255.255.0. Internet is connected to the firewall through 2 leased lines.
Now, I have a DHCP router, which I want to connect to this network so that any wireless devices, DHCP can give IP from pool(which is not used in static ip pool). How can I configure this? I would be happy to share more information, wherever needed.
1 answer Last reply
More about static network wireless devices dhcp
  1. usually you would use the DHCP function of the firewall and set the router up as an AP
    http://www.tomshardware.com/forum/36406-43-convert-wireless-router-wireless-access-point
Routers Static IP DHCP Firewalls Wireless Networking
