Archived from groups: alt.cellular.motorola (More info?)
I have Mobile Honetools v2.20, and a V400. I managed to get the
software installed and able to recognize and communicate with my phone.
If I click the Multimedia Studio Icon, it opens the program and hangs
for a couple of minutes. I SHOULD be able to see a list of
files/folders in the panel on the right, thats my phone. Currently
there is nothing listed at all, an apparent lack of connectivity with
the phone. Why this, the most important part of the software seems
incapable of accessing the data area of my phone, is above me.
Any ideas?
I have pictures that I want to download to my computer. Fortunatly, I
have been able to use the phones built in web browser to download
several .mid's and a couple of .mp3's to use as ringtones. why should I
pay for midi files, when there are several million available for downlad
all over the internet?
Torrance Bell wrote:
> *I have Mobile Honetools v2.20, and a V400. I managed to get the
> phone.
> hangs
> with
> Any ideas?
> I
> should I
> downlad
> Torrance *
Hey guys,
Are you still having the same issue? I dug the hell outta Google while
experiencing the same issue you guys seem to have. I'm using a v400.
Either way, what I did was I basically kept on troubleshooting. The
first step would be to disable everything from your start-up before
installing (so basically uninstall the software, go to "Start" -->
"Run" --> "msconfig" --> go to the "startup" tab and write down the
name of every prog that is unchecked...then if you are using XP, you
can click on the "Disable All" button at the bottom and then "OK," or
if you are using any other ver of Windows, go back to the General tab,
make sure "selective startup" is chosen, and then uncheck "load startup
group items." Then when you click "OK," let Windows reboot). Doing so
will prevent programs conflicting in the install to run, as you will
have temporarilly disabled them. Once the install is complete, go back
into msconfig, select "Normal Startup," go to the "Startup" tab, and
uncheck all the programs that were initially unchecked (if applicable).
If this fails, I have TONS of troubleshooting for you guys to try. So
lemme kno :-) Feel free to e-mail me at sashkoguard-cf@yahoo.com if I
don't respond on here in a timely fashion or wutever :-)
