Mini White USB Wireless Wi-Fi 802.11b/g/n LAN Adapter with Antenna Fre
Chip: Realtek RTL8188S
Standard: IEEE 802.11b/g/n
Effective working distance: maximum 15m indoor and maximum 50m outdoor (varies due to different environment)
Frequency range: 2.4-2.4835 GHz
Channel: 13
Support network protocol: CSMA/CA with ACK
Transmission mode: DSSSSensitivity: 54: -68dBm@10% PER, 11M: -85dBm@8%PER, 6M: -88dBm@10%PER, 1M: -90dBm@8%PER, 256K: -105dBm@8%PER (typical value)
Antenna: 2dBi
Security features: support 64/128/152 bits WEP data encryption, WPA encryption, IEEE support 802.11 x, TKIP, AES encryption
Support system: Win 2k/XP/Vista/Win 7/Mac/Linux
Interface type: USB
Adapter size: 37 x 19 x 7mm
Antenna size: 90 x 30 x 10mm
Weight: 18g
Package weight: 45g
1 answer Last reply
More about mini white wireless adapter antenna
  1. It may be fine or may be a POS, if you look at Newegg under wireless USB adapters the ratings vary greatly between models.
Configuration Support WiFi and Home Networking Wireless Networking
