Archived from groups: alt.cellular.motorola (More info?)
I'm trying to sync my v525 with mobilePhoneTools via blue tooth.
Initially, I had paired my computer with v525, then ran mobilePhoneTools,
it detected the phone but couldn't verify pin(I entered the same pin as I
used to pair with computer)
I tried unpairing with computer and powered bluetooth off, then on.
Now when I try to run mobilePhoneTools bluetooth set up and I run detect
devices and use the FindMe option on the v525
imobilePhoneTools doesn't find anything. My computer will still find the
phone. I've tried it with computer paired and unpaired, rebooted computer
etc Any Ideas ?
Winxp sp1.(I'm using the v500 option on mobilePhoneTools as there is no v525
option)
"HappyHiker" <HappyHikerUK@email.com> wrote in message
news:409380d2_2@mk-nntp-2.news.uk.tiscali.com...
> etc Any Ideas ?
v525
> option)
Mine will pair then during set up get message " Comm port Installation
Failed"
& will go no further. Am I missing something in set up
> etc Any Ideas ?
v525
> option)
Don't know what you boys are doing, mine works fine, do the mobiletools
updates thou
Ginger,
What settigns do you use, how did you set the thing up to get it to work.
I only have options for V500 or v600, not even a v500m.
Did you just follow the setup wizard when you log on or try something else ?
"Ginger" <ginger@helpme.please> wrote in message
news:c76jfo$fqi$1@sparta.btinternet.com...
mobilePhoneTools,
I
computer
> > etc Any Ideas ?
> v525
> > option)
> updates thou
1st off have you got the new version V2 20 not v2 16
run the auto update to get it
I have v525 on my screen but I am using usb cable
I think the v525 came on the update to v2 20
news:4097737a_2@mk-nntp-2.news.uk.tiscali.com...
> Ginger,
> mobilePhoneTools,
as
> I
detect
the
> computer
> > > etc Any Ideas ?
no
> > v525
> > > option)
> > updates thou
