Hi all,
I have a CAT5e cable coming into my new Atp. from ATT, the phone jack was cut off and I need to install a new one, but the wire coming into my Apt. is a Cat5e cable, just a standard 4-wire phone line.
Can you tell me what colored wires are suppose to be used in the regular Phone jack that only hold Red/Green and Yellow/Black out of the 16 wires the CAT5e cable has?
My DSL modem only has a standard phone jack input so I have no choice as far as jacks are concerned.
I can not get into the ATT box to find out which are being used... and when I call ATT they want $100 for a chump to come out and look for me. yeahhhhhhh thats not happening.
Thanks again all!
Thanks again all!
