Tom's Hardware > Forum > Audio > Pro Audio > breaker keeps popping on power amp - solutions?
Forum Audio : Pro Audio - breaker keeps popping on power amp - solutions?
Archived from groups: rec.audio.pro (More info?)
I've aquired a rather old solid state power amp (from 1971) that I'm
trying to get fired up.
Every time I turn it on, the power light glows for a second, the VU
meter twitches, and then I can hear the breaker pop and the whole thing
dies.
Turning the amp off, pushing the breaker button, and turning it on
again repeats the process - a fleeting second of glorious power, and
then death.
I'm not a genius when it comes to surgery on my gear, but I know some
basics. I inspected everything inside and didn't see anything obviously
out of place.
Any idea about starting points for figuring this out?
TIA
JT
Sponsored Links
>dies.
>then death.
>out of place.
Power supply capacitors. Supply rectifiers. Output stages.
Disconnect the power supply from the output section. Does it fire up
and hold? If so, the supply is probably at least partially good.
Might even be something going into oscillation from a bad decoupling
cap, though. You don't know, though, until you have checked the supply
caps and the output stage.
On some amps it can be worthwhile to fire them up on a variac and
look at where the current is going. But anything from 1971 is going
to have so many bad capacitors that it might be worth shotgunning all
the electrolytics before touching anything else.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
On Thu, 19 Aug 2004 21:31:38 GMT, j t <jt.REMOVETHIS@tydirium.net>
>dies.
>then death.
>out of place.
>TIA
Check the power supply.
>JT
Rick Ruskin
Lion Dog Music - Seattle WA
http://liondogmusic.com
Reply to Anonymous
- 0 +
> --scott
I would shotgun the amp as well
a deerslayer will be much more satisfying than buckshot
George
Reply to george
The most-likely problems are a short in the power transformer or the rest of
power supply, or shorted output transistor(s).
Replacing all the elelctrolytic caps is a good idea, just on general principles.
However, electrolytics rarely short out. New capacitors is unlikely to fix the
problem.
Do you have an ohmeter? Can you get the service manual?
Reply to Anonymous
> dies.
> then death.
> out of place.
*Something* is drawing a fair load. As suggested it could be a failed
output stage.
You could start by looking for shorted output devices. Anything much more
than that is going to need decent tech knowledge.
Graham
Reply to Anonymous
Thanks for all the advice.
Basically, I got this thing for almost-free, and figured that getting
it running would be a good excersize for my electronics and gear maint.
skills. I've got MUCH better gear in my 'real' rig - but this dinosaur
seemed like a good place to brush up on some basics.
thanks
JT
Reply to Anonymous
>> --scott
I think you all are a bit quick to toss away a good thing. I just
picked up an old Dynaco SCA 80Q at a garage sale last weekend. It
didn't sound all that great. An SCA 80Q is a PAT4 preamp packaged
together with an ST 80 amp with a little bit of fake quad thrown
in. I bypassed the entire preamp section, thereby converting it
into an ST80 and it sounds pretty good, when kept at moderate levels.
I don't believe it has seen any re-capping. Personally, I think there
is a madness out there to re-cap everything in sight, often unnecessarily.
Rob R.
Reply to Anonymous
Rob Reedijk <reedijk@hera.med.utoronto.ca> wrote in news:cg5obv$j1j$1
@news1.chem.utoronto.ca:
>>> --scott
unnecessarily.
> Rob R.
Rob,
I have a tendency to agree with you. I just had 2 pieces on the bench
both built prior to 1967 and all of the caps in them were fine. OTOH I
had the caps go south in my 3 year old computer. It would not boot so I
replaced them and all was fine.
r
Nothing beats the bandwidth of a station wagon filled with DLT tapes.
Reply to Anonymous
There are 775 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
